Must be in the dark for this one... So where did we get these 8800GTS 640mb GPU covers? Spend 9hrs daily doing TSA (Tech Support) work for Endo Rx and have thought I've found everything.. Are these custom?
BRY
BRY
yeah;) are custom made by duniek;) he does a very good job;)
Best regards
Well another UPDATE:D
first of all a pair of blue feser liquid;)
http://img393.imageshack.us/img393/2932/p1000887xq1.jpg
And now all second loop tubing just for see how they looks inside and to adjust little thinks: (WITHOUT any light);)
http://img167.imageshack.us/img167/1633/p1000888yn8.jpg
http://img340.imageshack.us/img340/9977/p1000889la0.jpg
http://img291.imageshack.us/img291/2153/p1000890ep5.jpg
http://img291.imageshack.us/img291/8348/p1000891qe3.jpg
http://img182.imageshack.us/img182/7649/p1000893ka3.jpg
http://img182.imageshack.us/img182/8717/p1000894cp3.jpg
did you think that looks nice? Let's see how they looks with all light power on!
http://img174.imageshack.us/img174/1741/p1000895yl7.jpg
http://img174.imageshack.us/img174/8171/p1000896wu5.jpg
http://img174.imageshack.us/img174/9083/p1000897pd1.jpg
http://img148.imageshack.us/img148/6427/p1000899jp9.jpg
i think its the best pic until now:
http://img148.imageshack.us/img148/1862/p1000898vr9.jpg
And now some impresive pics as well, with the left door:
http://img148.imageshack.us/img148/2734/p1000900xj3.jpg
i know i know, tubing its out of the window, the tubing its only puted to see the distribuation.
I think its perfect case-rad aliniation:
http://img442.imageshack.us/img442/8969/p1000901tp5.jpg
And other pics:
http://img137.imageshack.us/img137/1774/p1000902ce4.jpg
http://img444.imageshack.us/img444/8050/p1000903mr4.jpg
http://img444.imageshack.us/img444/6114/p1000905sg6.jpg
Well i think its an important update too cos the mod its going all well as I would.
Best regards to all and thanks!
looking good
Really Good looking where do you have those plates from that cover the graphic cards ???
Well another update, now its turn to turn on the computer with bouth loops working!
Pics of all the computer, no time to make pics of all the parts.
I've changed the raptor 74 for a 150 w/o window, and finalli get a e8400 not an 8500 as fist i have said.
Pics while i'm installing windows:
http://img260.imageshack.us/img260/5978/p1000906sq0.jpg
http://img228.imageshack.us/img228/7310/p1000907yx4.jpg
http://img407.imageshack.us/img407/7094/p1000908it5.jpg
http://img407.imageshack.us/img407/9436/p1000910ei7.jpg
http://img254.imageshack.us/img254/7057/p1000911pr8.jpg
And now without light:
http://img407.imageshack.us/img407/2665/p1000916gy5.jpg
http://img212.imageshack.us/img212/8169/p1000917xu8.jpg
http://img291.imageshack.us/img291/5256/p1000918ei9.jpg
I have to make a lot of things...
Put all ram's with disipators, mod the corsair ramflow, make the panels, some blue and UV leds and more...
Best regards!!
That looks sick =) I love the black + blue lights + blue coolant, looks very clean. Is that all on a single loop? What kind of temps are you getting with that?
EDIT: Never mind, read first post and see that it's two loops, still what kind of temps?
Thanks a lot.
Yeah its 2 loop, the cpu loop is working very well, the 8400 at 4.020 1,34v its only at 17 ambient, 29 at idle, 32 at full.
the second loop its not working as the first but its ok too, vga's are 39-41 idle (first vga-secong vga) and 47-48 full, north at 31 idle 37 full, and south 28 idle 30 full, so its working all properly;)
Best regards!
That looks awesome :up: Why is the reservoir external? There is a chance it could get broken like that. I love your cable management. Also, is that a 680i board or a 780i?
External its the only way that i can put a big reservoir;) and its hard that it could get broken, its very resistent.
jeje the cable management until "murderbox" its the same for all mods;) sleeve all atx wire separately! jejeje
Its a striker extreme 680i, with new bios 1503 working perfectly:P
Best regards
Well some news and pics:
First of all, i have done the lateral panel, changing the exterior acrylic for an interior one a little bit black;) lets see:
http://img166.imageshack.us/img166/4823/p1000924wj8.jpg
http://img166.imageshack.us/img166/4153/p1000925hv1.jpg
Now some pics of the workcenter:P (without the panel)
http://img166.imageshack.us/img166/6657/p1000926jp3.jpg
http://img166.imageshack.us/img166/756/p1000927az0.jpg
http://img166.imageshack.us/img166/2205/p1000928gt0.jpg
http://img166.imageshack.us/img166/6885/p1000929dv8.jpg
And now with the panel:
http://img166.imageshack.us/img166/2505/p1000930oz0.jpg
http://img166.imageshack.us/img166/121/p1000931fm6.jpg
http://img166.imageshack.us/img166/3851/p1000932mp5.jpg
http://img166.imageshack.us/img166/2345/p1000933zf7.jpg
http://img166.imageshack.us/img166/4618/p1000936il6.jpg
http://img166.imageshack.us/img166/5567/p1000937aj6.jpg
Now some frontal LCD pics:
http://img166.imageshack.us/img166/6471/p1000934kf2.jpg
http://img166.imageshack.us/img166/8826/p1000935ns6.jpg
Well if you look at the Ram's you'll see that only 1 dim has the sink, i have to buy the other 3. I'm waiting for some 30cm UV cathodes and some blue leds:D
Best regards!
jaja well hereis duniek;)
jejej i like fat tubing too,but if you look at the tube that goes from north to south, you'll se that its hard to put them well ... but blue tubing looks amazing, pictures dont make them justice;)
Some 3mm leds for UV acrylic DD TDX arrived;) so i'll take some pics tomorrow;)
Regards!
duniek is the man :up:
Where'd the PSU go? I'm thinking about gettin this case, but is there still room for the PSU after the rads?
heay;) suberb seller!
PSU is at the bottom, there are only one 360 rad at bottom, there is no problem with the space, some people put a pa120.3 and a pa120.2 at bottom with the psu too;) take a look at most watercooled tj07 and you'll see the rad & PSU position;)
Regards!
How did you get the rad mounted on the bottom? Or is not secured...
UPDATE! i think this time i have made better pictures of the system with and without light. I've installed the corsair ramflow on the memories, look at pics;)
System completly shut down:
Firsts pics with light and without lateral part and without the ram cooler:
http://img186.imageshack.us/img186/5303/p1000939br4.jpg
http://img220.imageshack.us/img220/2343/p1000941lm9.jpg
http://img220.imageshack.us/img220/2479/p1000943tj5.jpg
http://img145.imageshack.us/img145/9105/p1000945wm4.jpg
A global view:
http://img213.imageshack.us/img213/3130/p1000948mg7.jpg
And now some better pics with cooler on it:
http://img213.imageshack.us/img213/1521/p1000950un8.jpg
http://img527.imageshack.us/img527/7286/p1000951yy4.jpg
http://img85.imageshack.us/img85/3171/p1000953qx7.jpg
http://img85.imageshack.us/img85/4057/p1000954ax3.jpg
A detail of the new UV cathodes:
http://img329.imageshack.us/img329/6932/p1000957gu6.jpg
Well its time to power on the machine;)
First pics with light:
http://img187.imageshack.us/img187/24/p1000958rq6.jpg
http://img137.imageshack.us/img137/5258/p1000959np6.jpg
Lets turn off the light:
http://img166.imageshack.us/img166/5315/p1000962tr0.jpg
http://img201.imageshack.us/img201/473/p1000964qg6.jpg
http://img166.imageshack.us/img166/7223/p1000965qu4.jpg
http://img201.imageshack.us/img201/3065/p1000966st3.jpg
http://img166.imageshack.us/img166/351/p1000967ug2.jpg
thats all for now;) new updates soon;) with 3mm LEDs on TDX;)
Regards!
PS: anyone know when i can get a rigid sli bridge?
do those filters you have installed on the back 92mm fans restrict airflow and if so how bad
thX for the tips SaNxU, appreciate the PM. Looks like the blue theme is comin' back. Props, bro.
Nice blue!
Looks to be some tube kinking around the GPU but.
it restrict a little bit, but its better to put them because here are a lot of dust:S
Thanks;) no problem with PM's! yeah i think blue-black theme its a little better than the others at my eyes;)
Thanks!
Yeah, its a begining of a kinking... the tube its a little bit short:S its the tube betwin northbridge and southbridge, when I change water i'll thange that tube.
Regards!
