So here is the story ... a rumor broke out end of november/beginning of december that Intel was delaying their quad launch. People speculated, there are wild rumors all over the net. Here is the Xbit article:
http://xbitlabs.com/news/mainboards/...rocessors.html
Here is another speculations:
http://www.engadget.com/2007/12/19/i...mds-struggles/
Several stories were written, Xbitlabs has a unique story explaining that Intel discovered that if the FSB signal is marginal then the processor could lock up on lower quality boards, typically 4 layer PCB (el cheapo boards).
This makes sense... if the errata were a logic problem, then dual cores should suffer too, but for quad cores, there are two bus agents sharing the bus, think of it like you and your wife each using a hair dryer, run one hair dryer fine, but run them together .. pull down too much and trip a breaker. The extra core on the die adds an extra load to the bus, this will create a voltage drop... if the board does not have the margin for that voltage drop, then the voltages will not be enough to generate the appropriate differential to GTLref.
Your board is not in this class, you have no worries. You are getting worried over nothing. Question, does it boot? Have you run software on it?
Also, Intel publishes on a fixed monthly schedule... if any new errata are found, they will appear on the website under technical documents and specification updates:
http://www.intel.com/design/processo...pdt/318727.htm
You probably had not heard of it because the Inquirer has not picked up on the update yet.
Jack
