Originally Posted by
del_fuego
Hey there Talonman.
My rig:
Q6600@3.6Ghz (400x9) @ 1.40625 (in bios, real life... who knows :shrug: )
Maximus Formula
4GB OCZ 6400 Reaper EB @ 960Mhz (5\5\5\18)... need higher trfc on this board.
8800GTS 512
Auzen Prelude
Assortment of Raptors and other shiz......
My loop has just the cpu (unlapped) and gfx on it. A 50z for the pumpage, Fuzion with quad shizzle, an MCW60 and for some radiator action i went with an MCR320 and a Thermochill HE120 i got cheap off egay. I've also used copper elbows in the loop because i cant stand the kinkage in a mid-tower case (Lian-li PC60) using this lame tygon tubing i got. Temps improved with elbows by the way if you're interested, well for me anyway. Everything is internal.... boy was it a squeeze! Oh, except for my psu (HX620) sticking out the back..... lool.
With an ambient of around 24C, my temps when priming small fft's were exactly 60C on the hottest core down to 56C on the coolest (Coretemp). I noticed that it was easier to pass prime on small fft's rather than blend which needed a few extra notches on the vcore when it got to the 896K test. This rig is 6 hours prime (blend) stable. You'll have to take my word for it as there is just not enough hours in the day for me to sit there watching prime do....... well, not much really. I dont run my fans at full speed (yate loons, HL's and a scythe for the HE) so i could maybe shave a couple of degrees off but i like the quietness and i know i've got headroom for the summer.
I might take my cpu higher, i think its got some more left in her but for now it will do nicely, you can tell i dont like stability testing cant you. Once i deem my rig stable i prefere to game, make music, watch films and look at boobs. Prime and occt just dont have the visual impact to keep me glued to the screen for very long.
Anyways, there are my temps. I hope you likey, eh?
Cheers :toast:
Dan.
