nice results eva2000! such a high FSB on this board ;)
old Commando still pwn :up:
New thread for a new bios :) Old 1604 bios results at http://www.xtremesystems.org/forums/...d.php?t=174868
Flashed to 1605 bios from 1604 this time it worked. Asus Commando vcore options only allow next vcore option up from 1.75v = 1.704v idle is 1.7625v = 1.808v idle. So this is it 1.808v vcore on E8500 and this E8500 Q740A493T continues to scale with vcore on Kayl Black FrozenSS 1/4HP!
Bios temps = -9C
Evap idle = -40C
Evap super pi 32M load = -34C
Evap wprime 1024M load = -30C
Room temp = ~29C
System Power Meter load = 265 watts
System
- Intel Core 2 Duo E8500 Q740A493T
- Kayl Black FrozenSS 1/4HP
- Asus Commando 1605 bios
- 128MB Gainward FX5200 PCI
- 2x1GB Team 6400C3 Micron D9GMH
- 160GB Seagate 7200.7 SATA
- Pioneer DVR-08 Burner
- Sony FDD
- 620W Corsair HX620 Modular PSU
- WinXP Pro SP2
CPUZ Validation @5320Mhz
http://fileshosts.com/intel/Asus/Com...cpuz_valid.png
http://fileshosts.com/intel/Asus/Com...mhz_560fsb.png
Super Pi 1M @5193Mhz
http://fileshosts.com/intel/Asus/Com...1m_8s859ms.png
Wprime 32M @5168Mhz
http://fileshosts.com/intel/Asus/Com...m_16s484ms.png
Pifast @5130Mhz
http://fileshosts.com/intel/Asus/Com...st_18s30ms.png
Wprime 1024M @5092Mhz
http://fileshosts.com/intel/Asus/Com..._533s657ms.png
Super Pi 32M @5099Mhz
http://fileshosts.com/intel/Asus/Com...9m24s625ms.png
Super Pi 32M & Everest Bandwidth @5119Mhz
http://fileshosts.com/intel/Asus/Com...9m21s859ms.png
http://fileshosts.com/intel/Asus/Com...verest_twk.png
Woot! You're on fire! Great results! :D
Ouch , impressive E8500 !! what is the fsb max please ?
Congratz for your oc old school "commando" :D
thanks.. definitely on fire!
helps to have cooler room ambients at 29C room temps evap was -40C idle, but at 33C room temps evap was hover just over -34C idle !
thanks :D
E8500 530-535FSB 32M on water with 555FSB max cpuz validation on water. On phase with 1604/1605 bios, Commando is weird past 540FSB. It only is stable on first bios save/exit at high FSB could cpuz validate at 570FSB but on subsequent bios exit/saves - it hangs on DET DDRAM :confused:
Wow, revival of the 965!
The commando seems to play nice with those wolfies, even better than P35.
Yeah Commando seems to like it to a certain extent.. wish my FSB was higher though heh
Go 965 :D
So this CPU clocks higher with Commando than with your Blitz Formula?
Nice results Eva200, but please do not create 2 threads with same setup, dont make anysense you improve a few Mhz and create a new thread :confused:
I merged the threads for you ;)
nah Blitz Formula clocks FSB higher than Commando. I only used Commando as I'm too lazy to prepare and insulate a fresh board. Commando was already prepared and insulated from prior phase change sessions way back heh
Considering with only 9.5x multi, cpu will be clocked to high FSB, either P35/X38 or Commando would need 1:1 divider and Commando is no slouch on 1:1 when properly tuned.. only 8-16 seconds slower for super pi 32M on P35/X38 DDR2 boards i guestimate :)
no worries :)
Nice E8500 George!
From the retail results here at XS, I think I have to get one too, sooner or later :)
The speed on just single stage is impressive.
Yup I'm amazed at what this E8500 is doing on 1/4HP SS!
Yeah oc'ing is nice :D
Super Pi @5155Mhz
Tonight room temps were a bit lower at 25C so decided to push this E8500 Q740A493T a bit more to see how it goes at 1.775v bios set vcore which equals 1.824v windows idle and 1.816v windows load :)
Bios temps = -10C
Evap idle = -41C
Evap super pi 32M load = -35C
Speedfan 4.32 CPU Idle = -32C
Room temp = ~25C
System Power Meter load = 290 watts
Click on thumbnails for larger screen shots
http://fileshosts.com/intel/Asus/Com...z_valid_tn.png
Super Pi 32M
http://fileshosts.com/intel/Asus/Com...9m17s516ms.png
Super Pi 1M, 2M, 4M, 8M & 16M
http://fileshosts.com/intel/Asus/Com...8s937ms_tn.png
http://fileshosts.com/intel/Asus/Com...1s593ms_tn.png
http://fileshosts.com/intel/Asus/Com...1s219ms_tn.png
http://fileshosts.com/intel/Asus/Com...6s297ms_tn.png
http://fileshosts.com/intel/Asus/Com...7s719ms_tn.png
Very nice set of screenshots! You need a cascade George...:yepp:
thanks .... yeah colder temps would help hehe
getting awfully close to sub 9min George...congrats but you better not beat me to it :D
oh thats right...my first round of E8400s were terrible, you will have no problem beating me to it :up:
hehe, that sounds like the correct recipe. i wish i had 900MHz CL6 memory though, i have to puddle through wtih CL7 past 860MHz'ish.
i'm fighting to get sub 9m 30sec with this E8400 on the phase right now with that same recipe just a pinch lower at 530x9 on the P5K3-Dlx, CL7 of course. doesn't look like 9m 30 is going to happen for me tonight though.
P5K3 Deluxe need 0.05v more vcore than Asus Blitz Formula or Commando for oc'ing and prime95 on my E8500 cpus... so maybe P5K3 Deluxe not the best to get max clocks out of for cpu end ?
hicookie did a quick time with a Gigabyte X48T-DQ6
http://www.hwbot.org/result.do?resultId=685943
maybe something to work towards
Utlimately will depend on the max FSB my cpu can handle on 1/4HP SS heh
who knows...it is a monster for SPi at high FSB and i have never had a problem with it at 500FSB+. the maximus extreme on the other hand...is quite the handful north of 500, and doesn't really out perform the P5K3 in SPi from what i have tested. plus the maximus extreme is busy working. plenty of memory to get through this weekend and then it has a stack of GPUs waiting to get their turn ;)
@eva
For Commando & E8400 1604 or 1605 BIOS which one is better?
I have a problem with Det Dram signal on LCD Poster after 500 fsb:S
nice resaults guys i'm happy commando can handle 45nm. How you manage to flash a backward bios? because i tryed too from award flash and afudos, and they didn't let me do it. They post a message when they read the bios version that is older than the one i use and the operasion stops. :confused:
