Nice review.
I'm surprised it's performing that well, interested to see more.
grats on the site, didn't even know you had done that! Could use a bit of "polishing up" on the design front, but content is what counts :P:
Nice review.
I WANT A SILVER ONE!!
lets hope DD makes it soon like there old TDX.
So Martin, your saying that I should get the MC-TDX instead of the Fuzion I'm planning on?
I'm going to have 3 blocks in my loop, an MCR320 and a Laing D5.
No, I'm not done thermal testing yet.
I made one run with the MC-TDX and it looks very close to a stock fuzion. I say that because I never did the proper testing with my stock fuzion and only have a rough idea. I've only made my usual full set of tests with the fuzion nozzled, so I'm backtracking a little bit so I can get a good stock comparison as well.
My recent 4.4mm Fuzion nozzle run with washer in place was about 3 degrees better, which is really close to the gain I got from the nozzle and washer, so the stock vs stock is going to be close. Then I'll need to start tinkering with the nozzles for a comparison there. It's going to take a little time to get it all sorted out, but it's looking to have very similar performance is about all I can say at this point.
As far as the top goes, I'd just recommend the brass top "Option". It's only $8 more for a solid brass top, so it's very affordable and that would be more durable than delrin anyway:up:
Cool!
Thanks Martin!!
I'll check out the brass top.
is the brass top the same as the original tdx top? I have seen the Danger Den TDX Uni Replacement Top for sale but it's £14.99 :(
thank you,i'll stick to the lucite top until my next order from DD ...:)
I like the clear tops, it looks great with UV liquid running thru it. It's a sweet looking block.....
yeah, this is my first block with clear top and im liking it ;) it's just i dont feel as safe when mounting it, im using d-tek fuzion on my other rig and i tight it as much as i can but not with this clear top block
i am no expert on broken tops, but i don't read to many articles of them breaking, unless your going sub zero....
that is why i love the clear, it looks cool while cooling, now you can't beat that combo!.......
