Yepp, i did
I've played Crysis for 1,5 Hours with 1,45 V & 729 MHz - all works fine.
I did this with 1,5 V and it works, so 3dmark is not the stability test at all. Could you please try HL2EP2? If you do not want to walkthrough the game, here's my save: http://www.filefactory.com/file/1de604/. You need about 3 minutes (with 1280x1024xAll High) to test, if there is no OCP there - this will be the conclusive proof.
P.S. Just for informaton - the 78X resistors are 63,4 Ohm each.
