Clemmmaster isn't wrong at all.
@Moc Yes, on Saturday. But let us talk about that rather somewhere else. :D
The compressor consums 460W @ 2bar low pressure/ 17 high so let me know your guess how many ccm it has. (R22 rotary)
Show me the SC15 unit...
It has 151W @ -40°C . Of course you can get better results than in the datasheet if you have lower condensing temps.
My modded Mach makes 385W @ -24°C.... I know whats possible.
@ Dago
Yes... its time to add me again on icq... 313-894-238 or email.
You can't go from a power consumption to the displacement espacially with rotaries and autocascaded system.
Some rotaries use small displacement with high motor power and it depends on refrigerant as well (I have à 25cc 3/4hp R12 compressor for instance). I can find the displacement if I know the gas (single stage) used and the serie of the compressor, but if you know the serie there's 99% chance you know the modele name anyway :D
300w are with R404a condensing temp 35°C
You can only do so if you have condensing- and evaporationtemp und the refrigerant. then you can compare to a dataspec of a similar unit. but this way it is only possible to make a rough guess.
