Have you tried the freeze the coolant trick on your Alphacool reservoir ?
No I never heard about that. :D
Subcribed!
good work so far..
Almost ready with everything now. :)
Selfmade-Shroud
http://www.lifepatcher.com/pc/ll/shroud.jpg
http://www.lifepatcher.com/pc/ll/shroud2.jpg
Multiswitch and Aquaero (Aquacomputer Equipment) worked into the Lian Li-Original Front Panels:
http://www.lifepatcher.com/pc/ll/ms1.jpg
http://www.lifepatcher.com/pc/ll/ms2.jpg
http://www.lifepatcher.com/pc/ll/ms3.jpg
http://www.lifepatcher.com/pc/ll/msae1.jpg
http://www.lifepatcher.com/pc/ll/msae2.jpg
The Rad mounted under the top:
http://www.lifepatcher.com/pc/ll/radmount.jpg
http://www.lifepatcher.com/pc/ll/radmount2.jpg
The other Rad like this:
http://www.lifepatcher.com/pc/ll/radmount3.jpg
http://www.lifepatcher.com/pc/ll/radmount4.jpg
The Swiftech reservoirs:
http://www.lifepatcher.com/pc/ll/topopen1.jpg
http://www.lifepatcher.com/pc/ll/topopen2.jpg
The cooling side of the case:
(some fans are missing yet)
http://www.lifepatcher.com/pc/ll/pumpsite1.jpg
http://www.lifepatcher.com/pc/ll/pumpsite2.jpg
http://www.lifepatcher.com/pc/ll/back.jpg
and that´s the hardwareside:
http://www.lifepatcher.com/pc/ll/hwside1.jpg
http://www.lifepatcher.com/pc/ll/hwside2.jpg
http://www.lifepatcher.com/pc/ll/hwside3.jpg
Just took AC-Ryan Meshpanel for the top:
http://www.lifepatcher.com/pc/ll/top.jpg
http://www.lifepatcher.com/pc/ll/top1.jpg
Stealthmod for the DVD:
http://www.lifepatcher.com/pc/ll/msae3.jpg
http://www.lifepatcher.com/pc/ll/msae4.jpg
http://www.lifepatcher.com/pc/ll/stealth1.jpg
http://www.lifepatcher.com/pc/ll/stealth2.jpg
http://www.lifepatcher.com/pc/ll/stealth3.jpg
http://www.lifepatcher.com/pc/ll/stealth4.jpg
Started to make a window for the coolingside
http://www.lifepatcher.com/pc/ll/window1.jpg
http://www.lifepatcher.com/pc/ll/window2.jpg
That is all for the first. Soon I will finish that all. :)
cheers guys!
http://www.lifepatcher.com/pc/ll/vfd.jpg
Wow, you've put a lot of work into that :up:
The bracket for the top rad is an excellent idea, and I like the front panel mods too. Can't wait to see it finished.
Thanx! I really worked with lots of love for detail. I cannot create anything like the murderbox, but I do my very best, to get a unique stylish case. I think, the 343b is not an everyday case like Tenjin07. Except the murderbox no Tenjin could give me anything anymore. They are everywhere now, so it is not a unique one anymore. :D Lian Li rulez! ;)
I guess, that I will use hot melt adhesive for that little window.
http://www.lifepatcher.com/pc/ll/window4.jpg
http://www.lifepatcher.com/pc/ll/window5.jpg
peebee,
I apologize profusely for not getting back to you on the "freeze" trick for the Alphacool reservoir. I totally forgot about it.
As so eloquently mentioned by pie_uk :
"fill the cap up with your choice of coolant and put it in the freezer for about 5 mins then once in a solid state screw it back onto your res tank and wait for it to turn back to liquid"
"you freeze it because its impossible to fill right to the top without the big air bubble inside the cap. hence if you fill the cap up (frozen) its a hell lot easier to then put on and wait for it to melt"
Hope that this is helpful. I think it works well.
Oh ok IanY. I removed it now anyways. Nice trick. But that is only for little funny testings :D
looks very clean and classy i like well done
Guess the tube must collapse a tiny bit, to compensate as volume reduces when the frozen liquid melts.
3M double sided industrial tape is great for mounting mesh and plexi. Virtually invisible. PerfPC stock it.
Great so far, peebee!
Thanks. I also thought about double sided tape. Even if it would be visible, it wouldn´t be a prob. It is only used inside, so nobody would ever see that. ;)
We have a tape supplier called "tesa" here in Germany. They also make doublesided tapes. 3m is also known here. I gues I will figure it out before I take the hot melt adhesive.
At least I have to wait until wednesday/thursday. I gave the plexi pieces to a fellow. He will add some mirror foil/leaf. Then you can only take a look inside, when light is turned on inside of the case.
Then I still have to order some LED-Strips.
looks great!!! i like the window mod and the front looks very clean nice work :)
really nice work mate, congrats :)
Thank you guys!
Now I received my mirror taped Plexi back:
Looks good in the mod :)
If I have my LEDs, I can demonstrate, that it is getting a simple window, when lights are turned on in the case.
http://www.lifepatcher.com/pc/ll/window6.jpg
Beautiful rig! Personally I'd use metall hose clamps, the ones you are using looks a bit weak.
Amazing! the builds around here get better every day.
Awesome... well thought out and well executed mods! I like it!
i love this multiswitch and aquaero display mounted into the front panels, nice idea :up:
hey mate
whats that led display your using?? and does it come in black/blue backlight??
cheers
Thank you guys.
@disrupt: It is an Aquaero from www.aquacomputer.de and it controls my whole Loop with Fans and temps.
You can put any colour by using a foil with the desired colour, because it is a vfd.
@Junkee: Yes, I just touch the panel at the spot where the Button was.
do they ship internationally?
i don't understand the foil thing...
i can't find any black alu brushed ones like yours...
(only silver ones)
edit: nevermind you have to purchase the black face place as an extra?
