can someone give me the dimensions of the inner area of the frame.
a drawing of the pot design that fits on 2900 cards would be great ;)
Can somebody measure these dimensions?
http://wodkaenergy.de/stuff/_Jan08/8800_mounting.jpg
http://wodkaenergy.de/stuff/_Jan08/2900_mounting.jpg
i think the GPU pot will fit with both cards (remove frame from 2900)... or is it only designed for NV 88er series?
I want to check the dimensions from older cards.. maybe they also works with this pot.
i think this will help you ;)
http://www.aqua-computer-berlin.de/B...n/twinplex.pdf
Lookin good LD :up:
No backplate at all? Besides, the bottom end of the insulation will not be sufficient under liquid nitrogen. Backplate is a-must-have, it helps distributing the weight and retention force aswell as it packs the neoprene/armaflex insulation to the PCB board.
Guys, LD GFX-R1 SLI fits on 8800GTX without any problem. ;)
http://ld-phasechange.com/images/LN2...iner/SLI/1.jpg
http://ld-phasechange.com/images/LN2...iner/SLI/2.jpg
http://ld-phasechange.com/images/LN2...iner/SLI/3.jpg
http://ld-phasechange.com/images/LN2...iner/SLI/4.jpg
http://ld-phasechange.com/images/LN2...iner/SLI/5.jpg
http://ld-phasechange.com/images/LN2...iner/SLI/6.jpg
Best Regards
Still no backplate? :/
@tiborrr: Don't worry for backplates, they are on the way, but now i'm waiting them for 1 month --> Duniek!
Regards
Forgot to post pics of balckplates:
http://ld-phasechange.com/images/LN2...ner/GPU/24.jpg
Different design :P
http://ld-phasechange.com/images/LN2...ner/GPU/25.jpg
Regards
Hii all!
Realy nice containers there as always LittleDevil...Congrats:up:
PM me the price of a unit please...
Thanks, Best regards,
Thunder Boy
New batch of LD GFX-R1
http://ld-phasechange.com/images/LN2...ner/GPU/26.jpg
http://ld-phasechange.com/images/LN2...ner/GPU/27.jpg
Best Regards
omg, crazy pictures ! crazy crazy !
clean job, always, always... :)
Amazing containers! I count 10 cpu pots there just needing a good home.
LD, do you have a machinist or do you do all this amazing work personally? Everything you make is amazing.
Thanks guys, all pots are made on CNC machine.
Regards
Wow.. how many pots do you have! thats crazy lol.
very nice pots.
