Thanks. ;)
Good to see you.. Can you please add the LE-1620 to hwbot database? :)
>Funkflix
I added the processor in this version of cpuz :
http://www.cpuid.com/download/beta/cpuz.zip
please let me know if it is better now :)
Slightly OT i know - but i *LOVE* that case - what is it?! :)
Thanks Franck! Looks good so far, but Name is a little bit bugged. I'm sure you can fix that. :)
http://www.abload.de/img/cpuzt85.jpg
Thanks. It is a Chieftec Mesh Bigtower.
Thanks for the posts funkflix
Now I want to see the X2 65nm 45W results....I think nobody here has them.
I have an BE-2400 but no good oc board (m2a-vm).
Reached around 3,3GHz with watercooling. Today max is ~3GHz with 1,6V. :mad:
11,5 x ref HT 282
http://www.abload.de/thumb/282-sp1mthr.jpg
10,5 x ref HT 305
http://www.abload.de/thumb/305-105-sp1m-55-4-3-nht.jpg
10,5 x ref HT 310
http://www.abload.de/thumb/310x105-5-4-3-5-1420i.jpg
CPU requires ~3W less than an X2 3800+ EE in idle and ~15W less under load (10x multi and 1,2V).
Hope it does better in M3A (if it ever arrives).
There is also a 65nm G2 Sempron (LE-1250), those results whould also be interesting.
@funkflix: Great results
achim~
Great chip Funkflix!!
It's really a good chip for gaming. And looking at price it is even more attractive :) !
BTW 3.8GHz on water is :eek: :shocked: :eek:
Athlon LE-1600 on air (sct ninja) :)
Max HTT
http://img266.imageshack.us/img266/2...0412httmu1.png
Max Pi1M
http://one.xthost.info/cichas/spi/Pi1M_22672.png
Max Pi16M
http://one.xthost.info/cichas/spi/Pi16M_911.png
Can you guys tell me what motherboards are you using to reach those limits on the CPU? and also can this CPU work on any AM2 motherboard? thanks
I'm using DFI NF Sli-M2/G. I think this CPU will work on any AM2 mb ;)
Goodram Pro 900 @ D9GMH. On screens there is about 2.75V on VDimm.
Max @ 2.85V:
http://one.xthost.info/cichas/spi/Pi1M_606MHz444.PNG
Strange hary, max htt on my crosshair is 412,5 MHz too. I can boot into xp with 450 MHz, but it only registers as 412,5(wich is correct) You noticed this? Great results both of you btw!
Hmm, i boot with 408MHz and then using clockgen, at >413MHz system always freeze.
That one runs 2h of Prime95 with 3510MHz 1,44V and normal ambients. Still a good CPU for gaming. The other 1620 does only 33xxMHz with 1,44V, but that is ok too.
Either way, I'll buy two and send the weak one back!!!!
That is unless you want to sell that BP? I'll make sure it has a good home!
Great results, FF! :shocked:
I just installed windoze on my new build and have starting to play with my LE1620.
After a few hours' fiddling, it's running at 3.2G / 1.35v (stock is 1.2), with the stock heatsink! (It IS pretty cool indoors, about 55F/12C)
It's running an overnight stress test at 3.3 as I type. A big-ass Zalman is on the way, and I really hope to see 3.5+ with a little more voltage.
Maybe I can give you and your fantastic chip a run for the money! :D
I'll post updates ASAP.
LE-1620 The little chip that could!
Gigabyte GA-M61P-S3 (NF 6100 chipset)
Absurd, ginormous, 800W power supply in an equally absurd Supermicro case.
(Thanks to the IT guys at work for tossing it in the dumpster!)
Middle of the road Munchkin memory. 5-5-5-12 at 800.
funkflix : are u using ice, in u r WB??and what board do you used??
