I missed this one. That is spectacular. Great Work! :up:
@DagoDuck: You need to make copper load tester (15mm thickness or more) with cartrige heater, now you tuned that SS for 180W and you got great temps, but unfortunately you don't know what will unit ''say'' if you test it with 200W load or more. I have a lot of experience with that, i try to tune unit for lets say about 180W and when i try with 200W or more heat, unit has totaly crashed, it doesn't even hold -30°c at 200W. If you want to tune unit for really high load it is strongly recomended to use suction accumulator, it helps alot!
Best Regards
What were your pressures at that load?
Yes, this I have also considered, LD. Thank you for your advice! :) By the next unit I will change the load tester!
Thanks, Tony!
2long4u, I believe I have forgotten this. This are pressures without load on unit. http://www.fmkonzept.de/images/refri...F/IMG_2052.JPG With load it's around 15 Bar HD -0,1 Bar ND at 21°C room temperature.
Best regards
Great work.
I like the case.
