I can't seem to find any revision number on my P5K-E.
Where can i find that?
Peeling off the sricker reveals P5K de luxe revision 1.0G iirc.
My pcb was made in Taiwan, how about yours SeLecT?
I will look tomorow ;)
I have the same board and an engineering sample E6300 (BO stepping) And those results you have are incredible. I have managed a 500FSB into windows once. 500x7 .But i was only on one core ( i was using an install of XP from when i ran an AMD FX-53) so it wasn't enabling both cores in windows. Still, my fastest Pi time has been 16.1xx secs. But i would be happy to know some of your Bios settings, to see if i can replicate your success.
It would also help if i had a bigger rad than my XSPC 120:1 rad.:P
Nice CPU you have there:up: What was your pll voltage??
Here my bios-settings:
http://www.abload.de/image.php?img=biosusl.png
Do a bandwidth test in Sandra and make everyone jealous over @ Xtreme Bandwidth.
The E6300 ist not anymore in my hands... it wasn't mine...
So i can't do an bandwidth test :/ sorry...
