VR Zone settled at 735/1050/1770(shader) default cooler.
http://resources.vr-zone.com/floppyimage/8800gt/oc.jpg
it has 275MHz of delta.
Try rivetuner separate clocking works really nice on XP. here is how to do it
The card you got seems to be a lot better than mine, now im testing the 2nd one.
Thanks, I tried the 1024x and it gave me around 500 points gain. I am dialing the card in more and I will get the PCIE speeds maxed as well.
Nice, makes me wanna sell my GTX.
I kicked over to Windows 2008 Server 64Bit for a Cinbench 10 run. A decent pickup from the 32bit XP run.
I also have an install for Solaris 10, I will probably play with that next.
http://fugger.netfirms.com/8800GT/c164.jpg
Glad you noticed. The 64bit performance is huge. I like this OS a lot, it gives you the option to install different levels of the server or 64 bit.
Beleive me, I notice EVERYTHING you do in cinebench..;)
Are you going to force me to volt mod those chips just to try and keep a few hundred points ahead?:rofl:
I use win2K3 server on that rig.. Wonderfull OS..Stable as hell..
Imagine full load,24/7 for months with no issues.
Like the add, set it and forget it.
nice clocks and pic of the back of the card.
it tells me the rhs88 wont fit for the vf-1000 i thinks
Get those cards voltages up m8s ;)
There are some 8800 GT cards that dont run more than 670 MHz on the GPU and 1000 MHz on the memory with stock volts and cooler. Just for your information :) Its a gamble, dont forget about that.
Edit: Woops my bad. I should look at the right screenshots...
I tested 4 8800GT so far from different brands and I wouldn't say 720-730 MHz is average. More like 700/1000MHz.
I'm itching to get one of these things overvolted and watercooled! :P
But I hope the power regs don't get screwy at >>700MHz...
FUGGER,
Have you yet peeked under the HSF?
I'd be interested in the power regulation. Is it 2-phase or 3-phase on your card? The PCB actually does allow 3-phase, like VR-Zone's review card which has empty pads for a 3rd choke plus a pack of FETs and caps:
new drivers are out from nvidia website, 169.02
can anyone confirm how this card runs comapred to a 8800gtx stock vs 8800gt stock from a money point of view i would really like to know.also if possible can someone run this card NOT overclocked for 1 quick 3dmark06 run and say cpu quad\dual clocked to 3-3.5ghz for a better idea of how this card runs in a non phase pc.bottom line is it faster then a 8800gtx,or no?
nice results fugger,4.8ghzx4,lol!!
nice graph
especially that shader @1770, Rest Stock bar ...holymoly.
the shaders oc accounts for 80.5% of the performance increase according to this graph :eek:
14190-12495=1695
13858-12495=1363
1363/1695=0.8041
"can anyone confirm how this card runs comapred to a 8800gtx stock vs 8800gt stock from a money point of view i would really like to know.also if possible can someone run this card NOT overclocked for 1 quick 3dmark06 run and say cpu quad\dual clocked to 3-3.5ghz for a better idea of how this card runs in a non phase pc.bottom line is it faster then a 8800gtx,or no?"
so its faster then a 8800gtx(or close)?still hard to tell with this review using a non released screamer(penryn) on phase at 4.8ghzx4 being quads cpu score raise it alot plus the cards heavily overclocked.i will do some research 8800gtx vs 8800gt..i get 12k 3dmark06 stock gtx with 3.6 dually,running quad add another 1,500-2k to overall score i think?
looks like ln2 might not even be needed for max clocks lol, would love to see what this can do with water/dice/ln2 and some heavy modding :P, btw fugger could if you wanted with sli of these take 3dmark06 record?
