very interesting tweak.... i might wanna give it a try..
Can anyone say how much improvement over classical copy waza tweak you get by doing it this way? Cause I think that it will be close to zero :D
All I see in pictures uploaded from different persons that have tested it, is a "COPY WAZA" gain and nothing more....
Could someone please test it like below:
a. without any "software tweaks" (windows tweaks) - put only ramtimmings etc. (I mean, DO LargeSystemCache=1 and Priority=Very high for Super-Pi and things like that but without CopyWaza and things like that.....Only ramtimmings etc)
b. Then do what you always do up to now with only 384MB/384MB fixed Page File and Copy Waza from one disk to another (into Super-Pi folder)......Copy Waza ~768MB and more (doesn't matter if it will be 2GB)
After Copy Waza ends copying, close Explorer from task manager, close task manager and WAIT for some seconds till the HD led STOPS blinking....When it stops blinking, start the 32M
c. Do as CDT-Tweak describes
and finaly report findings?....:)
George, i'm doing such tests or similar i.e. no tweaks vs tweaks copy waza (doesn't work much for me) vs CDT-tweak etc
Will take a while since copy of files takes longer to do than running 32M Pi itself hehe
waiting for your research eva.... i think its just optimized copy wazza..
This is by elmor:
[QUOTE]
This tweak definitely works!
Pics up soon.
edit:
System specs, just straight boot didn't editing any timings:
http://bandwidth.se/imgs/1/74/sysspecs.jpg
Then just run without cw/cdt:
http://bandwidth.se/imgs/1/74/nocw.jpg
And with the previous OPB CDT I learned from him:
http://bandwidth.se/imgs/1/74/cdt.jpg
Now, how about with this new OPB CDT-IV tweak:
http://bandwidth.se/imgs/1/74/opbcdt.jpg
Wow, how about that? I just shaved of 16 seconds of a SPI 32M round!
I'll explain exactly how I did it as some have some trouble understandning how to do this tweak.
First you will need to set your maxmem to 600 (I used 620 which worked good aswell, though I belive the file 600+32MB is 600MB = avaliable ram and the extra 32MB is because of pi 32M calculation, am I right Kevin?) and also I believe it is very important to have a 512-512MB big pagefile on the SPI-partition (D: in my and Kevins case). Ok, now the instructions:
1. I created 1x 632mb file using the command "fsutil file createnew D:\myfile 647168000" (1000*1024*632) for a file of exactly 632MB.
2. Then I put it in a RAR-archive with the Store Compression method for no compression.
3. After that I renamed it to myfile2 and then myfile3 and after each rename add it to the RAR-archive with the Store option so that you get a 1896MB big RAR-archive.
4. Then I transfered it to my benchdisk with an USB flashdisk (I created the file on my laptop) and put it on SPI-partition (D:\file.rar).
5. Now you start SPI and select 32M calculation and press OK, but don't press OK to start it, let it wait there.
6. After that you copy it three times to C:\file.rar and the two other times you have to overwrite of course.
7. Next you copy D:\file.rar to any folder on D:\, for me it was D:\cw\, three times just like you did to C:\ before.
8. Now, as Kevin says, to balance it you copy the file C:\file.rar to D:\file.rar and overwrite it. I did it three times and I saw the ammount Avaliable memory raise each time.
9. Now you can close the Taskmanager if you had it open for monitoring and all the other windows not related to SPI and now you can start your calculation!
Hope this writeup helps you understand Kevins outstanding tweak better, I can only imagine what it takes to be able to find this tweak out.
BTW, I didn't get the Avaliable memory and System cache balanced so System cache was about 2MB more. If I can get those two balanced maybe even more gain is possible.
Please remove that last part, it might be bugged. (the last pic)
Tested, and can confirm it works.
I did a SPI 4M on a old socket 604 dual xeon. Time with no tweak was 3M 45.500Secs after tweak time was 3M 38.594Secs.
A difference of 6.906Secs or a 3% increase!
A64 X2 6000+ at stock 15*200 ddr2 at 333mhz 5-5-5-12
No tweaks whatsoever,no realtime, no shutting down of services nothing.
http://img135.imageshack.us/img135/7209/stockvm1.jpg
The CDT tweak, and maxmem at 680
http://img339.imageshack.us/img339/1784/cdtvuw4.jpg
OPB, if you read this, you are one special dude man, you could have saved allot of trouble and accusations by explaining these sick tweaks :D like you did know.
Kudos :up:
how about this small progy instead ;)
As you can see the tweak works for 1M-32M tests and explains why OPB had better performance/clock than the rest. How about some people start doing a bit of apologizing?
I must sux at this kind of tweak or something.. like copy waza, CDT-IV may help sometimes but is usually <3 seconds improvement over no tweaks for me on WinXP Pro SP2 :o
Still maxmem 600M + CDT-IV was fastest for me still so. But probably I'm not doing copywaza or CDT-IV properly ?
System
- Intel Core 2 Duo E6850 L720A489 Retail
- Thermalright Ultra 120 Extreme with Artic Cooling MX-2 TIM
- Asus Blitz Formula 1101 bios
- 128MB Gainward FX5200 PCI
- 2x1GB Crucial Ballistix Tracer PC2-8500 in white dimm slots
- Memory cooling = 120x25mm Thermaltake 81cfm fan
- 80GB Hitachi 7K80 SATA
- Pioneer DVR-08 Burner
- Sony FDD
- 620W Corsair HX620 PSU
- WinXP Pro SP2
http://fileshosts.com/intel/Asus/Bli...hz_results.png
no maxmem + no tweaks
http://fileshosts.com/intel/Asus/Bli...5ms_normal.png
no maxmem + copywaza
http://fileshosts.com/intel/Asus/Bli...s_copywaza.png
no maxmem + CDT-IV
http://fileshosts.com/intel/Asus/Bli...34ms_cdtiv.png
maxmem 600M + no tweaks
http://fileshosts.com/intel/Asus/Bli...9ms_normal.png
maxmem 600M + copywaza
http://fileshosts.com/intel/Asus/Bli...82ms_cdtiv.png
edit: only real way i know how to gain 7+ seconds is raw memory bandwidth LOL
Would this mean if i could get copy waza to work this below run would of been sub 13min ? :)
http://fileshosts.com/intel/Asus/Bli...3m12s875ms.png
At the time being, there was no such tweak. It's a new tweak it doesn't cover old results.
And you should know better since you got the old tweaks from him and wich you tested and you know the result ;)
But i have no problem with apoligizing if the man finally comes back and post again like he used to :)
I repeat........Do as following and report back...... :)
@ elmor: DON'T say please that the "his" previus tweak works coz IF it DID worked as you claim, you could have BEATEN Gautam's 32M........No?...... ;)
P.S. Guys from OCX PLEASE, test with Copy Waza firstly and then re-run it with this CDT-Tweak..... ;)
You're wrong mate ;) , the tweak DID exist by that time, well not this one as this is the "final" by now CDT tweak, as you can see this is "rev 4" if you want to call a name to it :) , CDT tweak has been posted at OCX tweak section long time ago, this rev is little more effcicent than the older ones but this is "the tweak" that everyone was claimng for since the first OPB's 8.906s SPI 1M
btw this is Predator lol :)
At 3GHz only with 375MHz FSB? I'll give that 3.6GHz time a try when I get ahold of a cpu that can run 3.6GHz and above 400MHz FSB.
If you just want a better 32M time than Gautams at 3.6 how about this from OPB?
http://www.ocxtreme.org/opb/36gpi32mfastest.png
Copy Waza != CDT(-IV) tweak, you could say that the CDT tweak is a more advanced Copy Waza though.
LOOK BELOW V V V
will try this.. :)
thanks for sharing.. :)
PLEASE DON'T Bullshi(f)ting me elmor.....DO you want me to show you a 12.29m 32M at 3.6GHz right now and I'll tell you that it was done with MY tweak?....Do you?.......It's VERY EASY you know......I will run the 32M at 3800MHz and after the resault is out and I'm ready to screen capture it, I'll DOWNGRADE my CPU frequency via clockgen/setfsb to show me 3597MHz and YOU ARE READY.....12.29m.....THAT SIMPLE.....;)
EDIT: You must be dreaming or so IF you think that DDR2 (as OPB 32M above) can beat DDR3.....NO WAY.... ;)
We NEED "neutral" users to test and report back......;) :)
And why is that? I have still not done enough testing with the two tweaks I got from him so I can't say anything about that. I'm just saying that OPB has shown us a tweak that may very well be the cause or atleast a part of his very good results. If he had this by then or not I can't say but regarding if he had this tweak back then or not I'd say that if you continue to say that his SuperPi-scores are fake then you're just being stubborn and not seeing the facts. Another thing that was "against" OPB when he first was accused was that he got a better time at lower clocks. How about he had to lower those clocks to be able to keep the system stable while doing all this copying? ;)
I'm sorry but if you are unable to believe that this tweak actually works that is your problem, but if you're gonna keep bashing I don't see any point in your posts in this thread. We have already had "neutral" users reporting gains and keep in mind that these users don't know exactly how this tweak works and how to squeeze the max out of it. The steps I wrote was how I did it, not nessicerily how it is done for maximum gain.
