I guess the one last issue with the Lian Li is the lack of side vents in the bottom part, which the TJ07 comes with as standard. I dont really have the tools to mod such a nice case, and do it to a decent standard i dont think.
http://forums.hexus.net/showthread.php?t=120796
According to this Lian Li are about to release similar side panels, or such an impression I get from the answer.
I cut my v2000 panel's yesterday...i started with a dremel was taking way too long and it was hard to keep it clean....Did my 1st panel with a dremel...Thing is i made a few mistakes scratched the paint... :(
I did the second panels with a jigsaw and a metal cutting blade...Went through it like butter...Very clean...I should of used the jigsaw in the 1st place...
So 1 panel is fine the other is scratched up....(brushed alu) so i don't if i can just paint over the scratches...
Overall i wouldn't say it was hard..and you can pick up a cheap jigsaw for pretty cheap....
