Thanks for the offer! I imagine anything out of the mass produced norm would be high. Probably better places to spend that money like more aluminum and acrylic...
Ha Well thanks...:up:
Yes indeed...I can bet a Canadian winter would almost be phase :p:
Yep the orientation of the pumps etc are all correct. I don't think there's much recycling going on...the air stream is pretty powerful...the Panaflo is running full tilt...but the next revision will enclooe everything a bit more and make it a better "package" to keep insects and other nuisances for infesting and otherwise dirupting the operation of the apparatus.
For one I think I will stealth the tubbng so it isn't such an obvious "rig" and looks more like a litlte AC unit..stress on little..I don't want to hang twenty pounds of cooler off the window.
Thanks for the advice :)
Where I live it would not be an odd thing to be thinking...high power consumption...bright lights in varrious outbuildings at all hours of the night...
We get a lot of helicopters patrolling these wooded undeveloped areas looking for the activites typical of rural Americe :p: reefer plantaitions. stills, meth labs...
