GIve us somme OC results !!!
fast and lots :D
fast and lots :D
Hold up, wait a minute, 2.4V CPUvoltage and 3.4V Dram? :eek:
Are you sure this is the right bios? :D
Any word on the Chipse, X38 or X48? I think that we might see Asus release X48 based Motherboard before this year is over. What's your guys Opinion? And I can't wait to see this boards results.
THX!
Hope to have some numbers tonight. Its X38 Vegettoxp.
http://img.photobucket.com/albums/v636/loc_oc/X38.jpg
I'm very curious about NB-temps with the heatsink/wc-block as is, because adding that 8mm thingy to a 1/2" loop is a definate no go..
Very very stock/auto settings :D No water and no xtra fans.
http://img.photobucket.com/albums/v6...PSX38stock.jpg
Very interested in the results..... would love to see some work with DDR2 800 3-3-3-6 compared to 1000 DDR2 4-4-4-12 if that is at all possible with any of your sticks :)
Set Multi x6 and fsb 500 for start:D
AC should be enough for that...
Thanks SynGroW, if overclocking is good on this board, I think I'm buying one on the 12th Muahahahahhahaahaha.
DDR800 (1:1 divider) CL3-3-3-6:
http://home.hccnet.nl/J_Bongers/maximus/1M_CL3.PNG
http://home.hccnet.nl/J_Bongers/maximus/8M_CL3.PNG
DDR1000 (4:5 divider) CL4-4-4-12
http://home.hccnet.nl/J_Bongers/maximus/1M_CL4.PNG
http://home.hccnet.nl/J_Bongers/maximus/8M_CL4.PNG
Tests done with sub-timings set to manual (but with stock subtimings, so pretty loose)
Untweaked Win2K3
Summary:
CL3 1M: 20.047
CL4 1M: 19.735
CL3 8M: 3m49.547
CL4 8M: 3m43.797
DDR1000 CL4 is faster than DDR800 CL3
Are the BIOS's the same for these two boards?
How is the PWM area guys ? hot as the P5K dlx ? I just preordered mine , damn I have to wait at least 15 days pfffff and pay it :p
You can put some insane voltage true your hardware whit this board :smoke: :D
Show us the capability´s of that nice chipset!!
mine this still in the box :| , havent even had time yet to realy look at it let alone fire it up.
Thanks a ton for that SynGroW, really appreciate you taking the time to do that, would appear X38 isnt exactly like 975x where I was getting better speeds with cas3 800, over cas4 1000.
Guess that clears that up, cant wait to get my hands on a maximus.
EDIT: Any idea on the latency differences between the 2 settings?
I am dying to see testing of the air-cooled version of this board vs. P5K Premium :eek: :eek: :eek:
come on loco get that hd2900 fired up, :yepp: whats your first impressions of the board
Ok, some first tests:
CPU vcore is undervolted by ~0,05v (difference between bios setting and CPUz)
DRAM voltage is overvolted by ~0,1v (difference between bios setting and bios monitoring)
vPLL voltage is overvolting by ~0,1v (difference between bios setting and bios monitoring)
Also vcore is dropping by 0,015v under load with load line calibration enabled according to CPUz.
Will check these results later with a DMM.
Now some overclocking:
Setup:
Intel Core 2 Duo E6300 ES cooled by OCZ Vindicator
Asus Maximus Formula
OCZ DDR2 PC2-9200 FlexXLC
Asus 8600GT Silent
OCZ Powerstream 520W
Max. FSB @ vPLL 2.3v
http://home.hccnet.nl/J_Bongers/maximus/550.PNG
550MHz increasing vPLL increases max. FSB, so this result is CPU limited (validator link)
Max. mem @ 2.7v
http://home.hccnet.nl/J_Bongers/maximus/700.PNG
700MHz CL5-6-6-21 (validator link)
It seems that the memory isn't running as great as it did on my P5K. I can run 1m at the same speed on my P5K with only 2.55v (bios setting) but with different subtimings.
Also a 1M run:
http://home.hccnet.nl/J_Bongers/maximus/14640.PNG
14.640s this run is also vPLL limited (forgot to make a validation file, will do that next time)
nice info syngrow and nice fsb :up:
Does anybody, who owns a Maximus SE, knows if a swiftech MCW-30 fits on NB?
Dont forget it's a E6300... a 4MB CPU would easily do in the 13.X or even 12,9...
Powerful!:shocked: :shocked:
come on loco lets see what this x38's got up to p35 you've got 2.4volt vcore to play with ouch !
