Originally Posted by
saaya
nice results!
did you buy it or did itc lend it to you?
thats def a good cpu then, the 6750s i have here only do around 620 under ln2.
yeah, you def need a vmch mod badly, to get 1900+ stable you need 1.65+ i think.
Did the sb voltage help at all? i always left it at default so far...
max vdimm for this board is 1.95 or something right? too bad...
freak had this board at the awardfabrik ln2 party this weekend, but he couldnt get it to clock well i think. he said with the latest bios all dividers work until 400fsb, after that only 1:2 works. he tried systool but the pll of the board isnt supported yet, maybe itll work with some setfsb or clockgen option...
i think the 400fsb thing is a strap or perf level thing... how is the perf level setting on this board?
close to the max or can you always lower it by at least one level like on the p5k3?
oh and 3oh6, awesome pics and thx for sharing the mod infos, good stuff! :toast:
btw, pt1t, did you try the white slots on the board?
curious if they are better than the first ones like on the p5k3 :D
