ohhhhh so thats our goal is it macci :D
hehehehe
Ok Im 100% (prime/3dmark seti etc) stable now at 270fsb at default vcore (1.44) and are now at 280fsb.
I can loop 3dmark for ~30 mins at efault vcore (1.44) but had to bump her up to 1.60 in the bios from the 1.525 setting and this now gives me 1.52load.
She has been stable for ~25 mins so far in prime :)
These 2.4 are little rippers imo!!!! :toast:
Nice :rocker:
Well then, looks like I got some way to go yet :)
By the way what o/s are you using?
If Radeon what drivers?
What kinda speeds were you getting @ vcore 1.6?
I could ask you questions alllllllllll day
WinXP with any Radeon9800 driver, above 300FSB I just need to up the AGP to like 72 or 75MHz with SefFSB. So I basically boot up to 300FSB, adjust the AGP and then increase the FSB above 300.
1.6V got me up to 3.8G aircooled and 1.55V gave around 4170MHz R404 cooled.
Mine acts the same, if i go over 315fsb, it will boot into windows but every thing is slow.
hmmmm, som1 mentioned the same thing to me earlier, about SetFSB, call me a noob but wtf is that?
by the way i go into 3.9ghz got screenies 2 come. :banana:
1 Attachment(s)
my next adventure is to get cooling for the GPU and NB, watercooling comes to mind, good/bad idea or do I need a vapochill?
Hey nice one dood :)
I have my 2.4 now stable at 280fsb @ 1.52vcore and now working on 290. I tried the same vcore as what passed 280 but nup, pc rebooted so now Im at 1.55 and it can 3dmark loop but it cant prime.....so up we go to 1.57 :p
I wanna feel what you are feeling having 2.4C above 2.6ghz guys!!! :banana:
Very nice FSB there! :)
Seems that the Epox board can reach some impressive Busspeeds. Can you run a SiSoft Sandra membench at max FSB? Would be interesting to see how it performs at such FSB.
In the other 2.4C thread gabbax has a IS7 at ~315 or something :eek: :)
I still havnt seen the Epox boards available here in Aussieland yet though :(
My P4P800 does around 317 stock cooled..but wont go higher than 327ish no matter what I do (it does 327 with 5:4 divider thou ;)). P4C800 on the other hand does only 309 stock but 330-333 supercooled.
abo's SetFSB can be downloaded from this page (the P4C800 version will work with your mobo too)
You also need to download GIVEIO.SYS file and copy it to the setfsb folder. This file can also be found from the above page.
1 Attachment(s)
macci: thanks for that setfsb :)
and now for the si results *drumroll* please:
1 Attachment(s)
Very nice :toast:
Man I wish my boards would do that kind of FSB stock cooled :) (the albatron would do but its too damn slow)
Damn 320+ on any board even with non default cooling is insane!!!! Well done :toast:
I managed to get mine stable 290fsb @ 1.62vcore now also :banana: and now Im testing 300fsb @ 1.68vcore. It passes 3dmark loops but fails prime after a few tests....more volts ;) But tomorrow cos Im off to bed :)
I can't get SetFSB to work... What do you do to get it to work?
I have giveio.sys and the program seems to work, but checking with CPUz, nothing is done with the FSB... ???
now i can make 313fsb with this stupid MSI Neo2 865PE
stock cooling on NB
http://sites.rapidus.net/maxbleau/4068mhz.JPG
I fixed my problems with Windows, by using Win2k, all is stable @ 3.9GHz :)
What kind of 3DMark numbers are you getting with that rig?
macci:
I am waiting for my NB and GPU cooling before I attempt anything, I am guessing I should be able to hit 22-24k with the setup.
I can get 21378 @ 3.6GHz and GPU @ 460/375 Mem @ 400MHz
Now I am @ 3.9GHz and GPU should get to 500/410 or something, saying that with the NB being pelt cooled I should be able to hit more FSB out of this board, so I can keep getting closer to your 4.3GHz :)
