Some games seem to not be able to utilise the 2900 to its full potential...
Yep. Overclocking the memory past my stock 1000 doesn't get me any FPS in Lost Coast stress test, but you get about 100 in 3dmark06. I don't care that much about benching, so I just leave it at stock.
I actually lost ~1 FPS when I tested a 40 MHz OC on the memory compared to stock...left the GPU at stock.
Definitely GPU bottlenecked.
Nope, not true. I am running Rivatuner hardware monitoring to show the GDDR usage, and I have it going to an LCD studio applet for my G15. In BF2142 it used 536 Mb of RAM on Minsk. I am running 16X af, 2X narrow tent aa (so that's 4x samples), maxed in game settings, and 1920*1080.
I can only imagine how much Crysis and Bioshock will use with these settings. I have the Bioshock demo DLing now, so we'll know soon.
well ur right more ram does help but i was only talking about performance wise, there is a mere difference between 1gb and 512mb, i dont think its worth the price premium unless there was a 25-35% performance bump, i actually got two hd 2900's 512mb for 600bucks from someone and i am pretty happy i will have enough ram to run in crossfire mode,
Yea I see what you mean, but won't the GPU take a larger performance hit if the memory can't store all of the data? I could be wrong....I haven't seen too many bandwidth tests when compared to the GPU being OCed on the 1Gb card....TBH I haven't even bothered to OC my memory except for 3dmark. Doesn't even show a difference in gaming, as the GPU is the bottleneck. I guess if you OC the GPU far enough it may require some more bandwidth.
Here's numbers for thought. This is with a 512 MB card. The graphs are in the following order:
Mem only overclocked
GPU only overclocked
GPU and MEM overclocked
The overclock speeds for the gpu and mem, respectively, are 858/1796 (the max the CCC will allow, nearly a 15% overclock on both). Results illustrate a heavy bottleneck on the GPU vs. the memory, as was voiced by others earlier in this thread.
EDIT: Sorry, tests are @ 1600x1200 with 4x BOX AA and 16x Aniso enabled. (Vista 32bit) My system details are in the sig below, with the obvious exception of the vid card.
Interesting results....does the data on these bar graphs represent normalized FPS figures? I. E. 100+[(OCFPS-STOCKFPS)/100]? I'm unsure as to what '% no of OC' means!
Great job, I like your style. Straight up data :D
Heh, thanks. Yah... those figures are normalized. Here's the numbers in a spreadsheet if you're interested...
very interesting .
nice charts comparing gpu - mem overclocking performance on the 2900XT Truckchase . :bounces:
