Pretty cases! Is there room to put cables behind the board plate?
thank youQuote:
you can invert the psu plate on the v2000 which puts the psu directly under the divider.
Here's my contribution to this thread :)
http://i13.tinypic.com/43rcykh.jpg
http://i14.tinypic.com/4g7ynb6.jpg
There's not room behind the motherboard to coil up extra unused leads but there's room to route all the motherboard cabling. I've fitted all the board connections to come through cuts behind the board in the smallest of the V- series cases. There's 10mm of space behind.
looks very nice rick_fx only thing i don't like is the un-sleeved psu cable's sleeving them or investing in a modular psu would clean up the case very nicely.Besides that looks awesome!!!
Yes i assume it would. but splitting into 2 loops with give the most benefit.Quote:
All that with only one pump? and a D5? Wouldn't a DDC be better with the restriction 3 rads and 4 blocks will give? Shouldn't it use more than one pump?
By the way that's not my pc....
cheers
Good Stuff Rick_fx
For Now
Before
http://i196.photobucket.com/albums/aa3/Tboy012/N.I9.jpg
After
http://i196.photobucket.com/albums/a...2/IMG_0084.jpg
Still waiting for some parts to tidy things up
yes, what you basically need to do is make a cut on the horizontal divider (that splits between MB tray area and the lower PSU and HDD cage area) and then also make some cuts on the MB tray or at the edge of the tray such that there is more clearance.
i've been able to fit my 24 pin and all my other cables behind the mb tray.
hmm... sorry i've got no pics...
since we're all LianLi lovers...
here's mine...
finished profile shot...
http://i44.photobucket.com/albums/f9...0/IMG_1031.jpg
side view...
http://i44.photobucket.com/albums/f9...0/IMG_1030.jpg
opened up...
http://i44.photobucket.com/albums/f9...0/IMG_1018.jpg
my HDD wiring...
http://i44.photobucket.com/albums/f9...0/IMG_1016.jpg
shot of my fan shroud... *cough*Koolance*cough* style... :D
http://i44.photobucket.com/albums/f9...0/IMG_0991.jpg
radiator is a MCR320 btw...
nice stuff !!! im in the process of finishing my v2000 around 70% complete
I really like the way that 343 (is that the model?) fan grille blends in with the perf'ed front, very nice. Any thoughts on spray painting the inside framework black and maybe add those Lian-Li DVD bay covers? Or is the framework only visible in flash photography? I really like those cases, really searching for a reason to have 2 computers to make use of that pile of 'extra' parts...if I find one, the V-series is on the top of the list for a home for those.
Some nice rigs here... ive often considered grabbing a Lian Li... may well be my next case (between that and a Mountain Mods - depends on how much cash i have really!).
Geez, this thread soooo tempts me into buying a v2000b, if only I had the money....:(
Hey kinghong, what size of tubing are you using? Nice setup btw.
where im at the moment very messy still waiting on a hd cage an other stuff
http://img165.imageshack.us/img165/791/pcpics043bc6.jpg
stop being a tease and post more pictures!
the pic above is the only 1 i have worth posting atm
