Looks to be about 1/2" although a lot of people here use 7/16" over 1/2" fittings. Looks too big for 3/8" though.
what kind of bezel did you use on the dvd?
this bezel can you buy for lian li cases http://www.lian-li.com/product/produ...=6&ss_index=38
I love it, clean and simple, makes it look like it was easy to fit that much :banana::banana::banana::banana: inside of a small (relatively) case.
Noob - pretty much, the i.d. is 7/16 and the o.d. is 1/2 the advantages are a more secure tube with nearly no loss in flow rates.
Sc4mpi - can you give me the dimensions around the fan grill?
Where did you put the pump? I'm getting ready for my A05 build and that's the one thing i'm having trouble with. The rad is going on the floor of the case. I'm going for the stealth look.
oo havnt checked this thread in quite a while
-the tubing is tygon r3063 3/8th id,
-pump is mounted on the reverse of the hd rack
-and which dimenstions on the grill do you need?
Looks great man! Much better than my w/c efforts...:p:
Impressive setup!
Looks great. I have the A05 running on air ... your temps look great. Hmmmnnn, I was going to replace the case, but may give it another thought after seeing your most excellent build.
nvrmind.
Very Long overdue brief update (2 years O.o). Case is still alive and kicking although now housing much more modern hardware and in a different Form. Of all the cases i have used and abused over the years this proves to still be the most versatile case iv had to date.
Watercooling has been removed , as the case provides a very nice base for a air cooled system :)
Some more up-to-date pics. (not great)
http://img.photobucket.com/albums/v2...5/DSCF0725.jpg
http://img.photobucket.com/albums/v2...5/DSCF0726.jpg
http://img.photobucket.com/albums/v2...5/DSCF0728.jpg
updated Specs:
Cpu: Intel i7 920 @4.2ghz - Ultra 120
Motherboard: Evga x58 classified
Ram: 12gb 6x2gb Corsair 7-7-7-20
Psu: Hiper 880watt
Gpu: Ati radeon 5870
Sound card: Asus xonar d2
HD Array: 3x ocz 60gb summits (raid 0) & 300gig velociraptor
HD Controller: Adaptec 2405 SAS controller
Optical: Samsung 22x dvd-rw
My attention has moved onto cars in the last 2 years, and it was only through browsing that i stumbled apon this thread again :)
Great case still. I love small yet full featured cases like the A05.
