wohooo finally this new cpu-z reads my e6600 voltages correctly :up:
Correct voltages reading on e4300/e4400/e4500 too :up:
this version makes my computer crash to the extent that the power button doesn't work, and i have to turn off the psu... never had that happen with cpu-z before.
One question.
since yesterday I'm on Vista x64 (with these prices of memory I want full usable 4GB working), and I was wondering would it be possible to compile CPU-Z for native 64bit??
There's CrystalCPUID (http://dl.crystaldew.info/download/C...PUID413x64.zip) but I much, much more prefer your awesome utill!
BR
Nedjo
Mine doesnt shows correctly
according to CoreTemp VID is 1.35v
yep, reads my voltage correctly now and adds more spd info. thanks for the link mate :)
cool. got rid of the 3rd decimal place, but cool. reads 1.50v like everything else now
woot voltage fixed for me too
Reads core voltage wrong here , dumpfile is attached.
Vcore is in bios 1350v , cpu-z says 1.26v
Thanks Franck !
Is it possible to put a the CPU VID there too ? :D
Cheers works a treat :up:
nice work Franck
1.40.8
1.40.5
These 2 versions don't work with Vista x64
err sorry it just says Voltage 1.248 v under cpz 1.40.5
1.40.8 says Core Voltage and it shows up as 1.25 V
I just noticed it uses a capital V and not lower case v like 1.40.5
So what is accurate here?
According to core temp my VID is 1.3250
hey, where did the command rate go?
1.40.5 works fine under vista x64 but you have to run it as admin.
http://s184.photobucket.com/albums/x...1_bios0501.jpg
Voltage & everything works great here, thnx Mr. CPU-Z :)
At first, I couldn't run it from vista x64, it would just crash, then I downloaded it again, ran directly from winrar, it worked :) .
Now i have extracted it, and it still works, good stuff added, like the proper voltage readings with my e6600.
