maybe the abit is making it run on 1333 strap man
try an asus motherboard
this here is not an 6850 its an 6600, sry, but thi ios the most impressive core2duo i have ever seen:
http://img110.imageshack.us/img110/7104/4155zc5.jpg
aircooled 68°C :eek:
is that your CPU man
that's just absolutely amazing !!!
does it have high FSB as well??
70c =/ eeep..
as someone else mentioned, it seems rather easy getting this cpu up to 4GHz and running pi, but there still hasnt been that many thats able to primie stable for serveral hours
Gigabyte GA-G33M-DS2R in NSK3400 matx case, crucial ballistix 2x512, 7900GS xpertvision.
Bios F2 used
e6850@4ghz on air : thermalright ultra120
FSB@444, ratio 9x, vcore@1.56250v set in bios
occt version 1.1.0 passed
http://img411.imageshack.us/img411/9...t110nf5.th.jpghttp://img165.imageshack.us/img165/5...4ghzzs4.th.jpg
vdroop:
http://img165.imageshack.us/img165/7...14vcoreqq9.png
cores temperatures:
http://img151.imageshack.us/img151/9...h14cpu1ni4.png
http://img510.imageshack.us/img510/5...h14cpu2ux4.png
orthos 3h:
http://img254.imageshack.us/img254/9969/3h02oe1.jpg
3hrs isnt techincally "stable" IMO. 10hours ide classify okay.
and Large FTTs priority 9 ;)
Yup... Ran 514fsb x 7 1:1 ... Everything is the same cos I popped in the E6600 right after to make sure it wasnt something else....
I think its not just the Abit.... Its the chipset that makes it run at 1333fsb, the Performance level in Memset was even the same in both runs ( PL=6 )
Just water.... I was hoping these new cores will hit higher fsb but I didnt get a good one:(
which is the right one for getting the stablity? by orthos stable... small ftts is all thats needed? not blend?
ive seem alot of people posting orthos with small ftts and not blend
This is proof of what getting carried away means. Many of us upgraded to this new CPU thinking it would make a difference but it really was not worth it especiall for users like me that already had an E6600 @ 3.6Ghz 450FSB 1066 strap. I am now running 4Ghz @ 1333 strap and really it is just bragging rigths. Ofc Orthos does not run more than 2-3 hours stable but games play fine which is the main use of this PC.
I will probably sell my older CPU or this one since it was ultimately a waste to get it now. Instead I bougth myself new a pair of new KEF IQ9 speakers a a 300Watt RMS 12" KEF SUBWOOFER (piano Black) and a new KEF IQ6 CENTRAL Speaker to ease the dissapointment and stop myself from buying a not needed Q6850 with a new motherboard.
My 2 cents (Euro ones)
Heres a single superpi....
http://i135.photobucket.com/albums/q...730-104712.png
im not sure it theres something im doing wrong... or if its just my motherboard but heres my max
apparently no matter how much more vcore i give after this point, it just wont boot
http://i196.photobucket.com/albums/aa3/Tboy012/max.jpg
first short test with my new E6850 retail Boxed:
http://pics.mwirths.de/pics/thumb/e6850_l719b016.jpg
L719B016
still testing...
Well my e6850 arrived just a few minutes ago. I won't be able to install for awhile, but here's the numbers.:)
Prod code=BX80557E6850SLA9U
MM#=891188
FPO/batch=L719B014
Pack date=07/09/07
look at my batch!
http://www.xtremesystems.org/forums/...&postcount=11;)
I CONCUR.
I have a gem of an e6600 Batch L629F (arguably the best OCing batch)
My e6850 batch 18a, seems volt hungry. Experimenting with AUTO voltage on a Striker Extreme, had it sucking 1.52 on 3.8ghz. I have to go manual voltage to 1.55v@3.85ghz to get through 3dmark01, 03, 05, 06 benches.
Trying anything over 3.85 would crash my system.
Cicolinos E6850 @ Dryice -67 Grad 5015 MHZ
Motherboard: ASUS P5K Vanilla no Mods
CPU : Intel E6850
RAM : CELLSHOCK PC9200
Cooling : Otterauge Alu Pod
http://www.abload.de/thumb/aufbaux87.jpg
http://www.abload.de/thumb/cpu-z5015mhzrfk.jpg
http://valid.x86-secret.com/show_oc.php?id=223201
SuperPi no Tweaks !!!
http://www.abload.de/thumb/superpi10.484hbc.jpg
Regards
SPLMANN
Could people pls list there cpu VID from the latest version of coretemp along with their overclocks :)
