mods should close all coolaler threads as the ones in the past as no one asked him if you can post it here......
Yup. Doesn't seem possible. I would think the cooler wouldn't perform that well due to not having a completely flat surface(small gaps between the heatpipe+heatsink). The machining doesn't look to be done that well either. However it looks a LOT smaller and easier to work with then the monstrous scythe infinity that i am using now.
well; the bios hardware monitor thingy says 27c at 20c ambient (ctemp says 15c)
so ctemp is probably reading about 10+c lower than
possible actual coretemp.
but i can say (like others) that the tuniq base is cool/cold to the touch even at load....so there:p:
i know people tend to exaggerate...but it is cold.
i dont think ill be running 4.0 ghz...but 3.8 is very easily rock stable at about 1.43v/1.39 droop.
i have no idea what the actual coretemp is :shrug:
i think im more worried about nb temps cos the cpu is 'cold'
But , basically, if this is indicative of G0 step heat (or coolness)
then a kentsfield G0 looks like an 'easy' 3.4-3.6 on air on average.
i dont think there will be many retail chips running 4 gig q6600 g0 on air :rolleyes:
but still; im going to be wishing i had a quaddie at some stage...
coretemp is off with its reading of g0 temps i think.
ambient is 20; and my guess is that idle ctemp is about 30 ish. (bios temp reads 27c)
i believe bios temp usually reads 3-4c below what actual coretemp is.... but i could be wrong
ctemp is reading about 13c ...which seems impossible.
from this it looks to be about 10c under my old 6700.
whether a q6600 g0 will be/is 10c+ less than current q6600...who knows?
the only really reliable temperature measure i have at my disposal is my fingers on the heatsink :lol:
I am certainly hoping temps are very good with the Q6600 G0 because I would be thrilled if I could run even 3.4ghz 24/7 with great temp ranges in the green!
P.S: Got my update from TANK GUYS this evening should be not far off for me...hoo hoo:cool:
Well from the looks of things, maybe I will be able to go with air cooling when my chip comes in.
From this post(if you can read chinese), coolaler said it himself that u need to add about 25C to the ASUS Probe CPU temperature reading.
Translated here
roomtemp 31c, coolered by tower120,
with default clcok,and P5K premium,damper disable, full speed over 55c, with damer enable,almost 60c.
Edit: tested at open room, not in a case
http://pic.xfastest.com/hicookie/cpu...fault_load.gif
http://pic.xfastest.com/hicookie/cpu...oad_damper.gif
Temp. is relative...As long as it can clocked like X6800 B1 on air (with double the cores) then its good:)
i h0pe the q6600 can hit 3.5ghz. ill be happy
he should of just posted it here himself. if everyone stopped posting things like this we'd all be bored and go elsewhere. his last activity here was 06-18-2007 so somebody else posting info here just helps him out. if he doesn't want to come here that's his choice.
First of all , the fact his not active here , it's due to some disagreement with some of the mods here , someting that I don't want to get into.
second, I have his permission to post it here.
also , About world debut , its marked with a question mark , as I didnt saw any other threads regarding this cpu, and since I know a lot of ppl waiting to see this stepping results, I asked coolaler's permission to post it here ...
i'm pretty sure you've been told about this already
he has been accused of cheating in both SuperPI and 3DMARK which he never refuted................and he stopped posting here himself........probably for the best so we should let him be
i'm surprised he would want to have his posts up on XS? is he in a need of attention he doesn't get on other forums or something? i seriously doubt that
What the heck did you all argue about that is so secretive? I just don't get it.....can't we all get along :) .
I didn't know your the first to tell me why he hasn't been here. if those in charge here think he's cheating then they should remove his posts. why should he refute any cheating accusations if he's not cheating. can you say for sure he's been cheating this whole time? XS can't just keep losing important members or else the quality will go down the tubes and this site won't mean anything anymore. you have to remember he didn't post this himself it's not his job to monitor this board that's why there's mods and admins here. We've already lost FCG and others. What if maxxracer, you, kunaak, AndreYang, eva2000, VictorWang, etc all stopped posting there wouldn't be much left. I know the board would go on but it wouldn't be the same.
I care because I like having only one place to go for my OC info.
could a mod plz close this thread befor we have a flame war :)
thx
