Some people want it for a few degrees lower BP, don't care about the pressures
Speaking of impure propane...is there any way to synthesize propane in order to get a more refined, more pure gas for our systems? I’m guessing this is a project for a much larger lab but I thought I’d ask anyway…there are a lot of good minds on this forum.
Just buy r290 propane from refrigeration stores, that will be pure.
LPG propane which most people use is about 95% pure, but it's allways worked fine for me.
Not under load for us :/
Unloaded temps are really great ...
No because pressures/temperatures mach to propane...
How long cap you use those temps? Can you tell what kind of mix was ref, fifty sixty, or something :D
For sure in our applications, but it's far from having the same cooling capacity like R507c, even if pressures are lower. R290 maybe a good refrigerant (according to data on R290 compressors) but propan gaz we find in France in tankstations are far from being pur ^^
No I'm not talking about GPL (LPG for you :p), the blend we put in our car that are called liquid petrol gaz, but propane bottle (13kg) we use here to heat food when we're not using Butane or don't have natural gaz at home :)
That's a well sized captube \o/
:up: hey mate thats like everryone says a nice build , but i really likethe neatness in the insulation so tidy in wrapping all them pipes up..must be tuff task having to insulate builds like these and a cascade.
