I really need to boost my bandwith, nice results around here :up:
With my new cpu: 11863 mb/s
http://img409.imageshack.us/img409/8...dwidth2vy2.jpg
Here there is a shot with DDR3 1800 Super Talent, and Intel achitecture (AMD architecture is more efficient because of memory controller integrated in cpu core):
http://www.atris.it/Forum/photoplog/...rf_level_6.jpg
I think it could be very useful to specify the version to be used for sandra and everest because results from different versions could be not comparable.
everything in ss below
sandra bandwith: 10278 MBps
Watercooled 6850ES and Cellshock 9200 !
http://img529.imageshack.us/img529/1...1mbsdq4.th.jpg
Regards
SPLMANN
that's better than what i run with the rig in the sig, almost in the same ballpark
:cool:
see sig :confused:
Not really tweaked and at reasonable 24/7 voltage (2.31V)
N/a
http://www.freak3d.com/clock/FSB483-...p266boost0.jpg
P5K3 Deluxe Wi-Fi
E6850 L22A*
Ultra-120 Extreme /w Scythe S-FLEX SFF21F 12cm fan
SUPER TALENT 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600 7-7-7-18
Thermaltake Toughpower 700W
1x 150GB Rapptor
1x Nec DVD Burner
ATI X1900 XT - temporary for testing
test setup out of case( going into Antec 900 case later)
Windows Vista Premium 32bit[/QUOTE]
step your game up
4.2billion% efficiency :D
http://img509.imageshack.us/img509/1521/91440462ug4.png
QFT Numa !!! :D
http://img58.imageshack.us/img58/5976/bproxxordz5.gif
Quick test with my DFI P965-S
e6600 @485 x7 3400mhz
1:1 OCZ UOE 485 5-4-4-10-4-15-6-10 2T Elpidia IC
evga 680i
evga 8800gtx
vista x64
decided to try out sandra 2008 and post results, had to use x32bit install since x64 gives memory overrun errors
Got a 6000+ to play with.
2GB kit (OCZ-DDR2-900 SOE)
http://home.comcast.net/~themysticwi...1075-55515.JPG
Pushed my memory a bit farther (537.5 mhz @ 5-5-5-15) requires 2.5v though.
Before I had it at 430 @ 4-4-4-12.
Not bad for Corsair CM2X1024-6400C4 v 2.1.
But I do think I need some better memory now that I got this new mobo.
Yes mate.....I wondered about this also.
The memory is OCZ SOE DDR2-900 (5,5,5,13,2t) but seems to give lower read speeds than the ADATA DDR2-800 (5,5,5,15,2t) I had before.
These dimms even run to 491mhz with 4,4,4,10,2t but give almost exactly the same results as 5,5,5,13,2t with literally only 200MB/s increase on read.
Maybe I've missed a setting somewhere :confused: Or perhaps ADATA just make better dimms than OCZ :down:
not as yet no. I'll go try another version now.
edit
I can't seem to find any older versions of everest......so I grabbed Sandra.....looks about the same here. :confused:
Thanks a lot for the test, but with sandra we are not able to understand if memory write bandwidth is greater than memory read bandwidth.
Memory read is the same! (edit: it is very low compared to other results in the same thread with the same architecture)
my write bandwidth can exceed in Everest...
just see my earlier post. also, somethign of interest for you Soldner...
http://img209.imageshack.us/img209/6011/image10gi1.jpg
read bandwith with and without C+Q running. and the bigger score is C+Q ON!
