Beta IP35-Pro bios update today
http://fugger.netfirms.com/M629B_12.zip
Try Beta bios' at your own risk
@FUGGER : what differeent with Bios 11 version ?
so far, i see lower latencies according what is reported by everest.
slight anomaly in Uguru cpu temp reporting...i got about 2-3C drop in temp.
It works for me. The only thing I see is the CPU temp seems to be recalibrated; it reads about 5C higher (E4400), and closer to reality, now.
I flashed with FlashMenu, from file (select All Files), and while overclocked. I don’t recommend you flash while overclocked.
Did a quick test with super pi 1mb everything on stock and with bios11 i got 16,984 and with this beta i got 17,124 with same setting. Seem weird when you guys get better score with this beta. I flashed in DOS and used this parameters /py /sy /wb /cd /cp /cc /cks . Is this right or have i forgot anything ??
