Yes. thanks.
Here you go:
http://resume.jbhfile.com/temp/ic_1.jpg
http://resume.jbhfile.com/temp/ic_2.jpg
http://resume.jbhfile.com/temp/ic_3.jpg
They did a good job designing a tight fit; can't move the chips within the spreaders at all ... and the thermal pads are *not* the adhesive variety ... more gelatinous or something ... not adhesive, though ... which I like.
My old mushkin heat spreaders had the same problem as that demonstrated by your HR-07 link ... they slid around in the heatspreader and were a pain press into the RAM slots because the chip would want to displace.
:up:
Thanks!
One more question, what is the material used on the black enclosure? Aluminum?
In that case Im wondering if this would beat both the spirit and HR-07s
http://www.performance-pcs.com/catal...ducts_id=20711
These look great and thx 4 the review. The only problem now is finding a place that sells this in Canada.
Seems like there aren't even many places in the states taht sell them.
