BIOS Version is :
1XX: Normal
PXX: Performance
so...Beta BIOS has been risks,after all more test okay maybe release ;)
oh~~my god :shocked: if going on the windows table ,that to be about to great :up:
http://homepage19.seed.net.tw/web@5/...5/06160004.JPG
very very nice.. :) G0 is looking to be a high clocker.. :) intel is doing great.. :)
thanks for sharing.. :D
johnnyliu3377
what was the result on the original BIOS? I couldn't hit above 470 MHz FSB, & had some problems with the MoBo's work :(
700fsb?!?!?????!?!?
700 Fsb ??!!?? :shocked: :shocked:
MSI's BACK! :shocked:
http://www.uecitylife.com/img/28dd2c.../msi_logo1.jpg
Nice CPU u have there.
E0 E6850 on MSI P35 Platinum Combo FSB600:D
http://homepage13.seed.net.tw/web@5/...S-7338/598.PNG
what's max fsb you can do with 1.3vtt 1.4vmch
This is a miracle ... because i had this mobo and did only +- 500MHz ... this product is the same s**t like other MSI mobos ...
Tragical BIOS, unstability, poor OC ... i dont believe this OC ... maybe it is stable for 5 seconds?
MSI Also tried it for there self :D
E6850 @ MSI P35 Platinum + Corsair CM2X1024-8500C5
http://global.msi.com.tw/index.php?f...ame=tech_p35_1
http://global.msi.com.tw/index.php?f...ame=tech_p35_2
http://global.msi.com.tw/images/tech...verlock_07.gifhttp://global.msi.com.tw/images/tech...verlock_10.gif
First time i see an Overclock guide on an MB-manufacturer-site :)
dfi is coming out with one too when they release their lanparty p35
Are you to play pranks?!:ROTF:
This is a proof :
http://valid.x86-secret.com/show_oc?id=209010
This is nice, finally, msi broke their silence with a big bang.
johnnyliu3377
You didn't answer my question. Could You tell us, please, what was the max FSB with the original bios?
I woudn't make any hasty conclusion;) Probably johnnyliu3377 was very lucky, cause my sample of MSI P35 Platinum is pretty sh*ty - too many problems, too bad OCing (as for the P35 chipset). 'll try the modified bios 2morrow, & then we'll see if it could do a miracleQuote:
that'd only be a good thing for people who have been waiting for a better p35 board ;). if by the time the dfi / e6550 come out, x38's are showing to be great, then hey, maybe i'll get one instead as well. I originally thought that x38 would be ddr3 only, but it's great to see it's doing ddr2 as well.
I hit without ANY VOLTAGE adjustments (all default) 510MHz FSB stable with 6750 CPU and kingmax 1066 memory 2x 1GB at 5-5-5-15 with 9440 Everest memory read benchmark , look's like I need to try more :)
I got board rev 1.1 and latest 05 bios
I didn't read any topic before I buyed this board but now I see that are a lot of post on internet with 470-480 max fsb.. dunno if that depend on cpu or..
sounds great! have you actually verified the votlages to see that theyre still stock? i dont know how msi does things but some other companies when you leave it on default, it'll actually increase voltage for you when you raise variables like fsb. usually it raises it far more than needed as well
you have grey, white and yellow signs in bios, grey are default, yelov are safe and red are critical, my are all grey and set manualy.
