opps here is the 3d05 link.. sorry.
http://service.futuremark.com/compare?3dm05=3195437
im using some of the goo that came from the stock heatsink to hold my sinks on. and it doesn't work very well. i have no sinks on the back. i have quite a few extras that i might epoxy on, and redo all the others. then i bet the memory will break the 860mhz wall im at.. even with 2.0v on the mem it wouldn't go past what i had with stock 1.8.
do you guys know if the 1950pros have a coldbug? i would only be going to -30c res temp.. chiller on the card and cheap water on the cpu.
have fun moddin it up.. what kind of cooling are you using trans?
