:with:
there's another thread with the same name by Micutzu, that thread was 'cpu freq' free
Either the thread you are talking about got deleted, or this was edited...
FSB limited to 2.8ghz for now.. X1900GT stock cooling.
0 tweaks.
http://www.xtremesystems.org/forums/...d.php?t=144963
p.s. this one should be edited and non-related posts should be deleted ;)
I was not talking about elmor's thread.
This thread earlier said 4ghz/661/1050 and someone with a GTX had a score of 72,000 already, I think that changing it was a little daft.
Edit : score updated (+100 points :))
8800GTX
X6800 @ 3.6GHz , 400x9
XBX2 i975X
4x1024Mb C3DF 1:1 , 400MHz @ 3-3-3-5
8800GTX @ 661/1100
Very bad mobo :slapass: , it takes 1.7V MCH just to reach 400MHz FSB :(
I will try to mod it , 450x8 @ 1:1 should give a nice boost :D
http://service.futuremark.com/compare?2k1=9208864
http://img115.imageshack.us/img115/9158/67735jz5.jpg
I woke up early this morning and had some time to spare. Just one round as it runs too easy on these clocks :)
X6800 @ 515x7
DFI Infinity 965
2x1GB Teamgroup OPB ed 1:1 4-4-4-10
XFX 8800GTX @ 702/1188
Tagan 1.1kW
http://bandwidth.se/images/1151.jpg
http://service.futuremark.com/compare?2k1=9208856
A bit over 3.6ghz (set 514x7 in bios) so how about a 10mhz +/- margin? :D
Wow, competition is heating up. My jaw just dropped seeing that LH :shocked: .
Nice score Gorod! You sure you can't get more than 400 fsb? Mine did 438 before mods. Try without 4x DIMMs. FAST board though, 450*8 3-3-3 will put you way above everyone else ;)
Good job Elmor setting the bar at 71k. Will be interesting to see if 72k is possible!
Anyone else going to give it a shot with a GTS? I need incentive to Vdimm mod my board.
Wanna added GTS to contest, it can be faster than 2900XT ;)
And maybe good idea to add AquaMark, it's pretty old-school too, like 3dm2001
Yah man ... i tryed everything , 2 dimms , with other memory , all possible settings but no go . That particular mobo i have realy sucks , with default MCH voltage only ~ 350MHz FSB 3D benchstable . I had a nice XBX1 before , that did 450 fsb no problem ... too bad she's dead now lol . Anyways i will mod it in next few days and will see how it goes :) .
Btw , nice thread for sure - thx Micutzu :up: , spent 4 hours yesterday playing 3dmark tweaking "game" :) , very addicting i must say :D
3DMark2001 is an "art" bench.......This is the ONLY bench that you can tweak your system to the maximum coz it's system related.....When done, ALL benchies will be fast and accurate..... :) ;)
Tweaking 2k1 (except LOD of caurse coz it's only for the VGA), you are sure that your system is well tweaked for everything.....Then you find your VGA's levels.... :)
......and YES this thread IS VERY usefull and it was missed ALL this time.... :)
Thanks Micutzu......
x6800@400x9
dfi dark
team 1200
bfg 8800gtx@648/1080(is this the limit of gpu or not??)
Attachment 60039
I think it's better if the limits remain as established in the first post.
afireinside > OK, feel free to submit GTS scores also, i will do my best to update everything. I'd choose some clocks hard to do without mods as i didn with Ultra/GTX, just to make it a little tricky; i don't have too much experience with GTS's but i guess 641/1000 is hard enough right ?
Gorod > nice run mate, 450 1:1 will be screaming fast as the CH is already just behind elmor's killer DFI. Any gain from using 4 dimms ? Because only 2 should get you more FSB.
hipro5 > 100% true, in a week of benching 6 days is 2k1 tweaking and one day is 03, 05 and 06 benching. You're welcome about the thread, actually i wanted this thread also for a long time ;).
OK, 661/1000 for 8800GTS then. Let's see the scores :D.
Here's a quick 975X run for GTX class: 68953.
The board is pretty old now but the BIOS still has some nasty bugs and lacks some very important options (like Vfsb and PCi-e freq adjustments), but it's fast and that kinda makes up for it. There's still some stuff untouched, but elmor's score will be hard to beat.
Mmmmmmmm.........I'll smack you..... :slapass: :D
Use uGuru V. 3.0.3.0 and UPLOAD the PCI-E at ~127MHz.... ;)
Thanks for the tip, i'm already on it :D. I have a question for you about AW9D on PM.
wow Micutzu, very nice score;)
what's timing ram??
@Micutzu : Nice Score :up: :up: :up: !!! same Question with gandalfone ....what's timing ram ? :)
Thanks, 3-3-3-4, tRFC=18 ;).
Ahhh.......I forgot to add that IF you want higher PCI-E on AW9D-MAX mobo, you HAVE to feed it with over 1.9VMCH AND use a PATA HD and not a SATA HD coz you'll have freezes......Sorry....... :yawn:
Guys try Uguru V.3.0.3.3 .....:)
Great thread and lots of solid scores aleady too!
Maybe I can add some results soon. Think I have one just under 71k with 680i, when I was testing dom 10ks before. Interesting to see what platforms are faster with the clock limitations.
