only problem is your top model wont work. The line going to the second radiator is too long. So you would have a flow inballance.
You see now why i said its very hard to pull off precisely.
AT one point in time i thought it might be interesting to use a device called a squid. Its basically a wave maker made of plastic pipes. It lets current flow though one side and then change over to the other. The flow is held consistant, and changes direction.
http://www.marinedepot.com/aquarium_...id.asp?CartId=
But then i thought were getting too overboard here. And i dont think this method would work very well, but it would allow the coolant to sit in the radiator for about 1-2 sec while it swaped though each one you connected it too. I thought this might be interesting, but never had to guts to pull it off.
