Thank you NewBeetle-san :up:
First post updated with the correct vcore and vdroop mod.
Sorry, I didn't make it clear :(
I did the mod and its working but not in the way from your pic.
On your pic you marked 50k pot between 2nd and 7th pin of the APW Controller. It should be 50k(i recommend 10k) between 6th pin(FB) and 3rd leg (ground). Like the Vdimm mod.
Im assuming the vdroop mod can be penciled?
r these vmods compatible with the p5k-v? it's the same pcb, except for it using the g33 chipset. i want to do a pencil vdroop mod so baddly
so... is there a confirmed vdroop mod for P5K ?
Anyone got OVP mod for P5K ?
Need more than 1.92V for our E6700. :D
Pencil or VR to SMD and go clocking :)
http://img297.imageshack.us/img297/4809/vdroopri0.jpg
More pictures here :)
http://www.octeamdenmark.com/forums/...read.php?t=167
I dont know an OVP mod, but if there isent one, you migth be able to connect the 3.3 Volt line to the CPU and controll the volt with a resistor.
That was done on some of the AMD based motherboards a few years back!
Thanks for posting, Ill do these mods!
Any confirmed Pencil Vdrop mod? Thanks
EDit: I did this pencil mod and it works prefectly.
Anyone saved the missing screen for Vmch? I really need the reading point for it, better now then later.. :up: Thanks in advance! :)
Very fast, thanks a lot Learn! :toast:
Vmch do nothing - 1.5V or 1.8V and the same FSB.
Martin
by ent (little upper) but thanks for the report, will be changed, still i dont have the mobo, so cant try it..
this vdrop mod my P5KC work?
Just to confirm that this version is working okQuote:
Originally Posted by ent
:wave:
