Nice!!
I want to get this motherboard for a new Intel Core 2 Extreme QX6850-sample I got this week, but unsure about how my Tuniq Tower will fit. You wrote that it almost fits. Can you elaborate on almost? Please?
Nice!!
I noticed the plastic caps myself but didn't think much of them...in that i didn't know what function they served. The heat generated from the various heatpipes seems much cooler the my P965-DQ6...add to that the nature of the heatpipes means one of them is close to a fan which is sucking air/heat from the heatpipe.
Here's a SuperPI run i did, see sig for settings. Memory is running 1:1 with 4-4-4-12-2T timings, 2.0V
425x8, Vcore set to 1.400V. (G)MCH and FSB set to Auto, PCI-E frequnecy set to Auto.
I ran all the SuperPi tests....is 15m 51s good or bad?
Irev...can you also confirm the quirk i noted in Q-Flash..as in only one 1MB bios chip being listed and lack of being able to flash the backup bios?
I know GB say this a safety/design feature...just want indepedent confirmation.
Also...have you noticed they have gone back to using the slower STT flash parts?...the P965-DQ6 used different flash bios and the flashing process went much faster.
Some more tests, Latest build of Everest, and some HD Tach results using a 32K stripe, RAID 0, did a quick and long benchmark, then i installed Intel Matrix Storage Manger 7.5 and enable writeback cache.
Everest, i don't have a full version :(
Why does this keep on resetting back to stock when I try to overclock. Same problem as before with the DS3.:mad: POS GB. How come this won't go past 426x8 even when it is set to 438x8 in the bios?
I am at a loss to explain also, it's either the CPU or memory...people have suggested a CPU will only reach a certain FSB, some porcesors get to a higher FSB then others.
Anything past 448FSB and my bios disables the overclock. I have tried a 6x and 7x multi.
I agree with that, the bios is better at a fialed OC, it'll try 3/4 times then disabled the OC in bios.
P35 Crossfire action on anandtech:
http://www.anandtech.com/video/showdoc.aspx?i=2990&p=3
It is failing at certain CPU clocks. I tried 438mhz and it failed but at 444mhz it booted up just fine. Does that sound right? Say if I tried 486x7 then would need to increase the CPU voltage? It is 1.45v now. I can get the memory up to 533 5,5,5,15 no problem. Also is there anyway I can increase the memory performance as it seems lower than my BX2.
http://valid.x86-secret.com/show_oc?id=198632
Thanks for the Tuniq pics. Seems its "good enough".
Those plastic skirts are for support and aligment purpose. The caps on this board are surface mounted and not thru mounted. Thats why those skirts are necessary to ensure the caps sit vertically on the board and not tilted or misaligned.
FYI, surface mount means that the contact legs of the device (can be caps, chips etc) are soldered directly onto the surface of the circuit board. The tiny resistors and ICs used on this board are surface mounted.
Thru mount means the contact legs goes thru the circuit board and is soldered on the opposite side. The inductor coils (those black square boxes)are such examples.
I think I figured it out after a failed overclock. If it fails for me resets to original clocks I had before like 444mhz on the boot up screen. All I did was completely kill the power to the motherboard by moving the selector on the PSU and turn it back on 5 seconds later and this is what happened. I did this twice and it seems to work so far. Very odd indeed.:shrug:
http://valid.x86-secret.com/show_oc?id=198664
Here are my results so far on the DS4:
I have been in windows at 640 mhz on the ram but wasnt stable.
Dont think my cpu will do anymore.
http://zager.homepage.dk/oc.jpg
can you run the memory asynchronous like RD600?
So how did you get 500FSB?...as in what bios options did you enable/disable?
it means that you can overclock CPU without overclocking memory...
So (G)MCH/FSB and PCI-E voltages are set to Auto?
Have you left PCI-E frequency set too Auto or 100?
DLL RAM setting to Option 1 or 2?
What's your DDR2 voltage set at?, what brand of memory are you using?
I'm starting to think the G.SKILL HZ won't allow anything past 450FSB.
