Probably doesn't make much of a difference. Temps only vary a few degrees throughout the loop.
I cant tell if it goes pump..rad..gpu
or
pump..gpu..cpu
would'nt it be better to at least hit his res 1st?
Hi,
Basically, I cut the mesh right down to the bare necessary (although when I look back i dont think you need to).
Just put the fans you want to use in the Mesh bracket up the top, then use the bolts that come with the rad (Stealth GT) to screw down through the top of the mesh, through the fans and into the rad. Its nicer to get some smart socket cap bolts rather than the ugly ones that come with the rad.
thats it really
Tom
man this thread is like doolgasm
the laws of thermal dynamics suggest it wont matter, since the water temperature will hit a certain "point" anyway, in a closed loop it wont matter what order you do the loop, just as long as the pump is before the res. i have also kept the length of the tubing as short as possible to keep efficiency
Update Time::D
Scythe Kama Meter
Scythe Kama Bay
http://img525.imageshack.us/img525/6...0071096nu0.jpg
http://img511.imageshack.us/img511/6...0071098fh6.jpg
Looks great! Does that Scythe Kama meter control 4 fans?
I have that same Zalman controller, but I spraypainted the back of it black and now it looks like a black faceplate. You can't even see the blue tint anymore. Was going for an all black look. =)
Yes Kama Meter control 4 fans+4 temp sensor :)
Nice idea Zalman looks great in black :D
i do wish i got the tj07 with the see through side panel. cant buy it on its own ?
@rockford, how does your loop flow?
and what south cooler are you using? cheers bud
@welshtom
http://i116.photobucket.com/albums/o...ntitled-15.jpg
you see my red circle, there is a joint like that at the top on the same side, did you have to cut this off? otherwise how would you fit the dual rad in therE>?
he is using this one :
http://www.noctua.at/main.php?show=p...s_id=7&lng=eng
Another update Apogee GTX+XSPC 5.25 Reservoir:)
http://img404.imageshack.us/img404/7766/a6gn2.jpg
^^ nice what gfx card have you got? how did you manage to get 18k in 3d05 with an x1950xt
what made you change res?
Day use 1900gt Rev2
@Benchs Sapphire X1950Pro Dual Godfather:cool:
http://img113.imageshack.us/img113/3...0071335ga7.jpg
http://img505.imageshack.us/img505/7...0071329kq9.jpg
Old res is aluminium:shrug: This one is plexy;)
dual god father lol where can i buy that !!
oh and you are using primo flex, how does that compare to tygon?
also are you going to fit that maze or?
does that card have 2 cores?
sorry for all the questions
I buyed another Maze4 for second gpu i waiting this:D
Primoflex is very flexible and I think better than tygon:)
Yes 2 X1950Pro Core 512x2=1024mb GDDR3 36+36=72 pixel pipelines:)
Red One is 1900gt Rev2 :D:D:D Blue one Godfather
http://img152.imageshack.us/img152/5...0071314wk7.jpg
yeah looks so nice, would love one !! where can i but it lol
also 2x maze on that would be :eek:
I think tomorrow second Maze4 came :)
Well on this note, if one of you in the US has one of the drive cages from the lower portion of the TJ07 leftover I could use one. Drop a PM and we can straighten out the details.
Ty
I think some one here did a comparison of different tubing..? can some one link me to it! lost it
