interesting that you say that funky.
i never thought that the plastic washer was causing the movement.
you are right it can be twisted with one finger though, and that is too loose.
if it were tighter on the cpu the thing, regardless of the plastic washer or not wouldnt move so easily.
it twists and it moves side to side..
the quickest fix for this would be to put a couple of washers on the mounting screws so you can tighten it down further.
cpu temp wise its great.
core temp wise, its,,, eh ok.
but my ES has always had horrible contact from the IHS to the core.
my Delta on the core temps can be anywhere from 20-25c and up.
cpu temps not nearly as bad.
