Dude,
For starters...I made no "claim"...I just expressed a thought/opinion and secondly, I did it with a big ole grin afterwards, as it was intended to be a lighthearted crack.
That said,
You are the one claiming that you don't get the rebates ("out of about 20+ some stuff i bought from frys, newegg .... i never got 1 back ..."), you are the one claiming that you file them correctly, you are the one claiming that you won't buy with a rebate...
Partial quote from earlier post just a little over 2 hours ago: "i hate mail in rebate ... thats why i am going to get GSkill 800HZ"
and by the way, you are also the one that just posted a little more than 20 minutes ago (in the GSkills thread) that you ordered the Ballistix for $139, after mail in rebate.
Your quote from GSkills thread:
"MOST of the DDR2 800HZ r D9GMH ... some could be D9GCT as some mentioned, but they should all clock well i think... CL4 DDR2 1000 @ 2.25v ...
but i pulled the trigger on Crucial 8500 for $139 after rebate so ..."
Source:
http://www.xtremesystems.org/forums/...7&postcount=43
So just relax and have some fun and enjoy your new Ballistix...and if you need help in filling out the rebate form, just ask any of the guys that have posted here after you that they've had no problems...I'm sure that they will be happy to lend you a hand...maybe you can break that bad streak of yours and get your first rebate back.
