Well done Hipro :toast: :toast: :toast:
Dude. Very nice job!
Time for 2x1G clocking from now on I guess? :p
Let those Fatbodies RIP
Thanks a lot guys..... :) :toast:
Single VGA gets higher numbers in CH, LH than SLI.....plus these drivers are GOOD.....I couldn't believe that they could push even CH and LH, but they did after all.... :)
Yes I have read it..... ;) :D I use "water buffer" for the container and it holds the difference between idle and load within 2 - 5(max) *C...... ;)
Rams are maxed out.....They can do about 455MHz Cas 3-3-3-4 for Super-Pi only......esdee has puted his hand on them, that's why..... :p:
Yeap...... 400MHz Cas 3-2-2-2 equals with 437 - 440MHz Cas 3-3-3-x.....SO if I could play my Fatties at 417MHz, I had to play the GKX at ~470MHz with Cas 3-3-3-x....;)
Thanks M8 BUT NOT Striker for me......I'm buying an ABIT IN9 for SLI tomorrow.... ;)
I had the QUAD (Gorillakos') at 3930MHz with the Striker, 3890MHz with the EVGA and 4000MHz+ with the IN9......SAME config all of them..... ;)
Ahhhhh....... :D :slapass: :D
OK.....Nowadays the bench order has changed..... ;)
1. ALL of the benchies in 2k1 is with 4.8 LOD
2. Order:
a. Nature FIRST
b. Lobby Low 2nd
c. Car High 3rd
d. Dragon Low 4th
e. Lobby High 5th
e. Dragon High 6th
f. Car Low 7th and you know....re-run and re-run till it goes higher.... :)
TIP: Format PRIOR the instalation of the WinXP, the HD as FAT32 with 16K cluster size.... and when the instalation begins, don't change it..... ;)
I used Western Digital's tools to do so.... :) plus use the NEW directX.... ;)
I had a 2k6 benchie past week but it was done on my "general usage HD" with 100MHz PCI-E and QUAD at 5GHz all cores..... ;) I'll rebench it "real" tomorrow..... ;) :D
http://service.futuremark.com/compare?3dm06=1739578
:p: on 965 I agree coz it's "bugged" somehow with low latencies.....On i680 just NO WAY.....Find my posts of testing..... ;)
Thanks Vince.... :) :toast:
For the time been unfortunatelly yes......BUT I'm on trying to find a good 8000UL so to much my other one once again.... :(
Great job Hipro. It's really impressive run. :clap:
Really cool job hipro :D , congrats with the WRs, and sad about the mobos and you sticks :(.
Looking forward to see 06 and SLI ;)
Lobby low as second? Does it affect the maximum overclock for that specific test if you don't run it as second?
By the way, you might want to change some lods. Dragothic Low has always loved high lods and apparently, CH should scale better using high lod. Read BenchZowner's thread for more info. Exact numbers here
sitting here, eyes and mouth wide open - incredible single card results O_O
awesome work george this will be massive in sli wohooooooooooo
Great runs! :slobber:
That's a very interesting order...btw low CAS is fine on i965, its low tRCD that isn't. IMHO in the end both high lats and low lats are strong, they just have to be pushed properly. Lots of performance can be extracted from just about any config.
No words...:slobber: :stick: :clap:
First of all, awesome results. Secondly, Hipro, you truly are a master and a great asset to everyone here. So many top overclockers impress with numbers, but your helpfullness and willingness to share knowledge with others truly has earned my respect. Oh yeah, and the fact that you get big numbers too :D
Congrats George...waiting for SLI action;)
hehe tell esdee to stay off the rams next time :D .
btw last time i heart the mobo had problem with getting all 4 core's multie unlocked , is this fixxed ?
wow, awesome scores, congratz :toast:
you are a very big cloker, no words......:clap: :clap: :clap:
Hipro :D
Hehe Cellshock is not bad rams :p:
Bad days gone, and now only good days :)
This single GTX run is ... hmmm pretty:woot:
Congrats for You !
Martin
amazing, in 3dmark01 106k should be easy with SLI
Incredible single card scores! :toast:
:eek: unstoppable
:clap: very great man!!!
Adequately respect hipro5 !
too bad nvidia wont let you sli with a 8x8x mobo. :(
It would be great if you could run your AW9D settings in SLI with the 8800's.
Awesome awesome awesome!!!
"WOW" is the only word that can describe your skill Hipro! :D
Insane results :eek:
Incredible job! We are waiting for the SLI run :)
Good luck!
Alex
Incredible!!
Great job:slobber:
I didn't see this. Wow.. It feels like all those SLI numbers we have seen before mean nothing.
