Has anyone tried using a quad core in current 965 chipset boards?
I am running a Q6600 in a Shuttle SFF SD39P2 at 9x333 = 3ghz at stock voltage and runs like a champ. Temp went up 2 degrees when going from 2.4ghz to 3.0ghz so I suspect I have a killer chip.
mines running just nice at 9x401 fsb with 1.45 vcore ..I removed my vdroop mod before i insatalled the cpu. and it seems ok at 3.6ghz i wont push it any harder untill i recieve my chill control back as im just relying on the sensor on the mother board for evap temps..Asus probe and speed fan my temps are stuck on -2c it dosnt change..i dont know why but i would like it fixed..E6600 never had this problem..
anyone know easiest way to get a image to 200 kb without cutting the crap out of it ?
so with vapochill u can only get 3.6GHz??
and how come u only have 50% .. load ... try 4 x SP2004 and assign them to each cores ... not 2 orthos
Nope i havnt tried anything harder as yet..this cpu is performing better than my E6600 on less vcore.
so im hopeing 4ghz..but not untill i have my chill control back.
im blind atm what i see temp wise is only Gosple.
orthos you need 2 x orthos running for 100 % load..and yes i will run 4x sp004 just give me a chance i have had cpu 2 days...
boy u ask alot of questions...
did i answer them correctly :slapass:
i cant handle anymore than 1 question heeh 2 blew me away rofl
can someone just answer the question as to whether you can lower the multi with an XBX2?
i dont wana run my memory at anything other than 1:1
also, virtualrain, i love your avatar. who is that?
If thats 9x401 from bios youd be better of with 9x400.
Give P95 v252 a go.
Well since nothing but Extreme series chips seem to be able to be adjusted according to the BadAxe2 thread, I would venture a guess that.. no... the Q6600 is not adjustable with current BIOS's but I have no first hand knowledge.Quote:
Better place to ask the question is the BadAxe2 thread. At least you'll likely get more responses.
no you can not adjust the multiplier. at least i haven't been able to.
i had no problem running the ram at 5:4 or 3:2.
Was there / is there, a QX6600. It seems like either there was at least engineering samples...
http://www.devhardware.com/c/a/Compu...adro-Review/1/
http://www.xtremesystems.org/forums/...d.php?t=142026
listening in - considering Q6600/QX6700 when the next price cut sets in :slobber:
any specific steppings to look for?
I just got my q6600 today, as far as the multiplier, I can set it in the bios with my p5b deluxe and according to CPUz the multiplier is changed. The strange thing is the bios post screen and bios info say I'm running 3.6ghz but cpuz reports 3.2ghz 400x8.
Also another thing, no problems at all with 4gb 4x1gb of memory and 400fsb so far with initial testing with my old Asus P5B Deluxe. :)
Well, just hoping.. :D
http://www.dailytech.com/article.aspx?newsid=6488
Despite the mild Q2’2007 price cuts, Intel plans to aggressively cut prices on its complete lineup in Q3’2007, with the exception of the recently launched Core 2 Extreme QX6800.
Hope the QX6700 wont be totally phased out by then :(
IIRC, B0 ES were fully unlocked
Try raising NB voltage.
Asus P5B-DLX 340x9 stock vcore
Take a quad core system Install Windows, VMWare and 2 instances of Linux. Assign each vm 2 procs. Set the affinity to cpu's 1 and 2 to the first one, and 3 and 4 to the second.
Looks like about 3077 ppd with P2608's 13 minutes per frame per vm.
http://www.pbase.com/shadco/image/77932436.jpg
