Voltage? and CAS3 from bios? :cool:
Yum yum! I'm glad to see such an influx of shots already, great work everyone. Now we know who the real men are. :D
You're correct except that C3 BIOS set is very fast on i965. In fact, it matches i975, just look at my entry. ;)
I don't want to go nuts over verification because I just want to keep things fun. If its going to make someone feel better by faking a 500 CAS 3 shot by Memset, so be it.
Now one thing however, Bad Axe 4:5 shots also should not be posted as they are not real. Once again I just ask for cooperation, I don't want to have any b***ching over this. Bad Axe 4:5 was shown to be totally broken and people even got 600MHz CAS 3 shots like that. :S
Hehe, I know you'd like it. ;)
Dadgum--memtesting at such speeds and volts :lol:...I love it.
I'll probably edit the first post in a bit.
Okay now here's my entry. :cool: I see a lot of stuff at low CPU speeds, but here's a time whose performance matches the clock. ;) For those of you doing this on i965, I hear a lot about there being a CAS 3 bug and all- there is not. However I strongly recommend that you not use tRCD 3. It doesn't make clocks any easier but it hurts performance a lot. IMHO 3-4-4-x is the fastest on i965. 3-4-3-x looks okay too.
So, 3-4-4-8 BIOS booted, 1066 strap (of course) 2.9V, Team Group Xtreem PC2-5300, Asus Commando. Anyone doubting whether this is really CAS 3 can feel free to try and beat my time at the same clocks. :D
http://www-personal.umich.edu/~gautamb/500cl3.PNG
The clock for clock performance of this is actually even higher than what I got on a P5W DH 3-3-3 on the 9X. :eek:
Duh, yes. Though TBH I found tRP 3 to be somewhat of a headache with my config as well. Edited. :)
First off validation as always. Settings were booted from BIOS.
http://valid.x86-secret.com/show_oc?id=181144
System Specs:
Motherboard: P5N32-E SLI
CPU: X6800 @ 3900.00 on Jinu Modded VapoLS, Thanks Again!
Memory: Single Dimm 1 GB Corsair 8888C4D @ 3-3-3-8-2T (546.0 MHZ) Don't ask about subtimings, you really don't want to know :P
Voltages:
CPU: 1.61v
vFSB/VTT: 1.47v
vNB: 1.59v
vSB: 1.61v
vMEM: 3.29v
First snapped validation and shot, then ran PI2M, snapped again and crash :). Also look at CAS 4 Pi2M. at the same speed, with only CAS Latency changed. Only needs 2.15v, quite a change...
http://img470.imageshack.us/img470/8194/pi2mcas3hx7.jpg
http://img372.imageshack.us/img372/3049/img4553xd1.jpg
http://img372.imageshack.us/img372/7863/picas4ut8.jpg
Beautyful result, so a pity that only single channel :(
Please, share your settings from bios I shall make them very useful :rolleyes:
Thats very very fast for 4.5ghz Gautam :toast: On 1066 strap x-4-x is faster, boot above 400 and trcd3 should be fine.
Thanks, I actually got a score at 4.64GHz or so from when I was still learning the platform that actually scored worse. :eek:
But booting above 400 is never fine for some of us. :D ;)
Interesting to note though, I never tested 1333. Odd how tRCD 3 suddenly works there and doesn't with 1066. :confused:
Have been trying to get under 11 sec with 4.6 max but no go for me. Your cas 3 should do it easy. Best i could do is this. Wil try cas3 500mhz but it wil be on 1333 strap most likely :D .
I have some other Kits here,
Dominator 8500 CL5 and Mushkin XP2-8500 both with D9GMH
but they don't wan't to reach the Clocks of my lovly G.Skill 8000 HZ with D9GKX
@ all the Voltage lovers:
Pls don't give more than 3V on a 6-layer PCB this is the death for the Chips
on 8-layer you can go to 3,2+ with good airflow.
Do you guys cool your ram?
Well, since its my thread, I'll allow a threadjack. :p:
Sub 11/sub 4.6 is something I always wanted, and I did indeed get it :D Unfortunately you don't have the 12x multi. :-/
However before did pull it off on the 1066 strap and 9x.
I will say this though. CAS 3 500MHz looks great and all, but 600MHz CAS 4 is faster. Not by much, but it is. 11x 2:3 CAS 4 is better than 9X 1:1 CAS 3 unfortunately. :-/ I could beat that 4.5 gig time at 11x409 2:3 if I desired. A little perk of the X6800...
hmmm, am i the only one with 500mhz cas3 on AM2? :D :D
http://www.eclipseoc.com/image/teamgroup/506cas3.png
http://valid.x86-secret.com/show_oc?id=187851
Here's a good question.
Is anyone brave enough 2 use these timings and voltage 24/7.
heres mine with super pi run but it blocks timeings but first i took this SS
http://i68.photobucket.com/albums/i5...67890/5003.jpg
http://i68.photobucket.com/albums/i5...890/500pi3.jpg
also this is from bios not memset :)
Dfi 965-s
xeon 3060
cellshock 4.4.4.12 8000
Where do you live?? ALASKA?
lol ?
Your temperatures are extremely low :D
512MB XtwinZ 9100ES@3,2V 531Mhz Single Channel
http://valid.x86-secret.com/show_oc?id=180722
