Great looking build! This has me a bit confused though:
How did you reverse the pump?Quote:
ranker the "orange" is the uv dye from www.cool-cases-usa.com. The stuff would be more orange if concentrated, I had no idea how much water my loop actually would hold so I just mixed a gallon of distilled, pt nuke, and the dye. At night though under uv it IS orange, pics coming shortly. I might mix it with petras red coolant stuff just to get away from the pinkish hue.
And im pretty sure that just the 830 allows the reversal. You need rails for a removable tray on both sides of the case, pretty sure thats just a feature of the 830. I could be wrong though.
AuroraProject: Wow, that was a typo, sorry about that. I fixed it in my first post now. Thanks for catching that. I meant to say that once I flipped the EK 150 multioption res right side up bleeding was done in manner of minutes, all bubbles went away, and the pump was a lot quieter.
peace
thats a sweet setup dude, but im more curious about the pink dye that you claim is orange and the curly hair :lol:
That really is nice looking :D
Very nice job youve done :D
+1 to this statement
Just have the rear draw air in. You have a STACKER 830 dude. Your not making any wind tunnels here, nor is your case cramped without airholes.
You wont cause any pressure in that case because, ... blah... i dont even need to explain.... you can see it.
So just draw air in the rear rad. That way it will also do well cooling your board additionally and the mosfets.
Also very very nice job. You just solved a riddle i had about the stacker830. Board reversal solves everything!.
very nice job you did there. congrats.
i recommend some rubber edge trims for that backside though, you can find them from petra's or even mcmaster.
Very clean&good job :)
Sharp work! Congrats! :toast:
Very nice work dude.
I like how you keep everything simple.
Thumbs up!
Awesome Build man.. it looks way better then before.. :D
have fun with it :toast:
Damn thats a nice build! Remind me of one of my builds. I stayed up all night to do the wiring job and to make some holes and stuff :p:
Now enjoy! :)
A lot of hard work.
Thanks guys! All your rigs were what inspired me so double thanks :D
Ya once i switch the fans around, Ill get some niiiice airflow over those Thermalright mosfet coooolers when I get some. Not sure though if the fact that my mobo is flexing (the GTX is on pretty good) will ruin the contact between the mosfets and the cooler....i might just have to get little heatsinks for each one individually if thats the case
peace
woke up this morning and im at 35 degrees both cores!! (1.45Vcore)
Updated "command center" :D
http://i23.photobucket.com/albums/b3...g/_IGP0343.jpg
http://i23.photobucket.com/albums/b3...g/_IGP0344.jpg
from the front, door open
http://i23.photobucket.com/albums/b3...g/_IGP0351.jpg
from the front, door closed
http://i23.photobucket.com/albums/b3...g/_IGP0352.jpg
more pics
http://i23.photobucket.com/albums/b3...g/_IGP0357.jpg
http://i23.photobucket.com/albums/b3...g/_IGP0354.jpg
http://i23.photobucket.com/albums/b3...g/_IGP0350.jpg
All Uv cathodes on (one 12" and two 6")
http://i23.photobucket.com/albums/b3...g/_IGP0360.jpg
Only 6" UV's on
http://i23.photobucket.com/albums/b3...g/_IGP0359.jpg
No UV cathodes
http://i23.photobucket.com/albums/b3...g/_IGP0358.jpg
side off
http://i23.photobucket.com/albums/b3...g/_IGP0362.jpg
http://i23.photobucket.com/albums/b3...g/_IGP0368.jpg
http://i23.photobucket.com/albums/b3...g/_IGP0376.jpg
Quick question guys. Would a low speed yate be enough for the rear mounted BIP? or do you guys think a medium speed would suit that rad better?
thanks
Very sweet lookin'!!! Without overdone bling. I like it a lot!
Rear mounted? Are you sure you don't want it somewhere with cool air? A low speed yate is okay really, unless you don't care about noise too much. In that case throw a more powerful fan on.
well ill be switching the direction of flow on the rear BIP so it will be bringing in air. Like some others have said (which makes a lot of sense if I think about it lol) how it is now, im just pulling the hot air from over the mosfet area through the rear rad. So if/once I switch around the rear fan I think i might just get a low speed yate, either that or try to buy a sunbeam fan controller to pair with a couple medium speed yates.....decisions decisions
thanks for the comment btw
go yates medium speed, you could always tune em down or up when you need em most.
try both ways (airflow) and compare which works for your setup given where its at on your table. you never now if cool air would come from your right side or left side of the room.
Damn! Great job :clap:
Outstanding job! I really like the loop layout... simple and effective.
Good lighting without overdoing it on the bling.
Just an all-around great job! :toast:
Mate that write-up had be glued to my screen :)
Well done, you've done a great job with the hiding of cables and mounting of all your gear :)
