Hi all
Im using a Macron 400watt, not pot adjusted. YET :) no need to really with those lines im running @ 2050 mhz 1.92 vcore.
5volt = 4.92
12volt=12.15
Hi all
5volt = 4.92
12volt=12.15
Enhance 460w rev 2.1
non adjusted / adjusted
KX7 - 333 / 9 x 210 / 1.95v / 80w pelt
5.01 / 5.04 @ 100% load
11.98 / 12.01 @ 100% load
IT7 16 x 173 / 233mem / 1.775vcore (1.73v actual) / 80w pelt
5.10 / 5.24 @ 100% load
11.86 / 12.09 @ 100% load
I should add that it was perfectly stable unadjusted on the IT7 and that this is yet another board known to be harsh on the 12v line. No complaints at all with this PSU. Better voltages than the antec truepower 550w I tried.
PiLsY.
I have an Enermax EG465P-VE (431 W). Currently running system at 11.5 x 145 (summer) at 1.85 V. As I am writing to this reply, I am surfing the surf and doing SETI in the background. I think this should qualify as load since I don't have Prime 95. With this setup here's what I get:
Solid reading very little change
+5V: 4.972
+12V:12.403
Keep in mind that I have an older board and I am not (can't) overclocking hard like some peeps. I have seen that the Enermax PS does not seem to perform well on the newer mobos. BO
enermax sux especially with an amd... thats why i sold mine months agoQuote:
Originally posted by Chong345
yeah, just from looking at all the first posts the enermax has not been doing so well
5v - 5.08+
12v - 12.75+
antec pp-412x
Vcore 1.8 1600 @ 1750
3.30V is 3.48V
5.00V is 5.10V
12.00V is 12.28V
Power supply is TTGI520SS
Thanks DaGooch ;)
Antec PP 403X 400watt
+5v--5.13v load
+12--12.95v load
+5v--5.30v idle
+12v--12.65v idle
Has adjustable pots an been adjusted. Been running 2years fine.
I know Pilsy has bragging about this PSU before and there is the proof of that. Looks like we have at least 2 brands to trust now.Quote:
PiLsY.
Thanks Pilsy,
Mac
Sparkle 400watt
+5v=5.05v idle
+12v=12.16v idle
Pc power and cooling turbo cool 475 watt ATX
12v=12.1v
5v=5.1v
THese lines do not change at all any load situation (damned expensive tho):)
Thats fantastic results!Quote:
12v=12.1v
5v=5.1v
I read somewhere that Pc Power PSU:s are the real McCoy, but they are more or less impossible to find here in bananaeurope.
What did it cost for you?
Thanks for the input!!
Marcus
PC Power PSUs are the only other PSU I would ever run. The reulsts they give are simply awesome. Personally i dont think any other PSU on the market can compare to them. They do, however, cost more than a ti4600.....
Mac - try looking for a samcheer 520watt (or 470watt at a push). Theyre also a very powerful and reliable PSU, which surprisingly doesnt cost very much. They also have adjustable POTs for 3.3 and 5/12v. I also had better results with the samcheer than the antec. Not to say the antecs a bad choice of course.
For an enhance 460 rev 2.1 use www.vgicomputers.com
For samcheer PSUs try www.microdirect.co.uk
For antec try www.ebuyer.com
Aside from those 3 then I think youre probably stuck with an enermax 550 or sparkle 400 watt. Again both highly capable PSUs, but not of the same quality or power of the 3 mentioned above. Youll also find the samcheer models to be VERY cheap compared to everything else.
PiLsY.
On that blue enermax 550w one, I got 5.02 and 12.10.
Sparkle 400Watt,
5V @4.97
12V @12.1
3.3V @ 3.6V
These values are underload with my VMem @ 2.95 and Vcore @ 2.02.
Paul.
PS Hi Mac...
Haven't tested the Antec 400 Watt Full tower Case yet!!
Hi Paul!
Nice to hear from ya!
I kinda hoped that you got the setup, but apparently not.
I call ya later.
Mac
Hey Mac,
I should be getting the setup this week m8. I have everything now to do the Case mods and watercooling setup... Brought up a electrical drill and jigsaw from the country last weekend. Will start hacking the case soon.
Paul..
PS Sorry for going off the topic here!!
It cost me 219 u.s$ shipped worked out at £150 uk money only took 2 days to get here too :DQuote:
Marcus
btw Randi uses a version of this you could ask him how good they are ;)
I really want to try a pc power and cooling psu but don't have cash for it.
toofast - where did you get that PSU m8?
I'll order one now :p.
Thx m8,
PiLsY.
just get the antec pp412x guys... adjustable pots and everything.. great psu
Gdang!!Quote:
Can you power a nuclear camp with that or what?
I know it seem to be good, but wtf?
And i thought 150 Euro was expensive for a psu....
Well, you live and learn.....
Thanks,
Marcus
Delta Electronics Dual-Redundant 600W PSU
5V Line - 5.19V
12V Line - 12.21V
I ordered it direct from Pc power m8 ;) was on special offer maybe it still is if you are quick :pQuote:
Thx m8,
PiLsY.
Having been through 2 x Sparkle 400 watters i wanted to try the best ,i talked to MrIcee and that made my mind up cheers m8 ;)sold both my RMAed 400`s which helped to finance the PC power :DQuote:
Gdang!!
Thanks,
Marcus
I checked out those PS at PC cooling. Damn, expensive and will make you go deaf. 48 dBs just from a PS, sheez. BO
Antec 550 Tru-Power
+5 = 5.12 under load
+12 = 12.66 under load
