Whoops fixed.
It's good to be curious about member's posts :)
Perkam
I'm getting this.. :D
Looks very solid. I might be getting one to replace my 500W Seasonic.
No EZ-grip on the molexs? That's like what...$0.01 per connector and it saves the finger pain :<
I'd think you can run G80 SLI on it; G80 SLi runs fine on a corsair HX 620, and that's only 50a. Granted, you'd need adaptors..
What do you think about OP750 & Quad-core w/ 2x 8800GTX or X2900XTX?
Well I recall quite a few people using 650W and 700W psus on kentsfield + G80 sli...overclocked...
Minimum recommended wattage for Quad core + High End DX10 SLI/Crossfire is an 850W power supply meaning something like this: http://www.ewiz.com/detail.php?p=PS-...85d03ba32f1597
With the cheapest good psu able to run such a rig being this one: http://www.sundialmicro.com/silverst..._1837_968.html
Perkam
Looks like it's powerful but how noisy is it?
does the OP650 have the same scratching sound like the DA/OP750?
thats good to know. i'm only planning on running one R600 card, XT or XTX. it depends on the gap between them. sticking with my current rig in my sig till quadcore is cheap.
Love Silverstones!
$128 at DeadEyeData and the shipping is less than EastLuna, at least for me.
130$ at performance-pcs and they ship to overseas
http://www.performance-pcs.com/catal...ducts_id=21200
Recommendation Suspended for now. Please check here: http://www.xtremesystems.org/forums/...d.php?t=140243 ... for the reason.
CLOSED.
Perkam
