Way to conservative a number
"Considering the 8800GTX pulls ~150W (being nice) when OC'd and the core uses at most 110W "
I would say 150w for the core alone. It is practically an order of magnitude larger that any CPU I ever laid eyes on, and I read it has more transistors than any CPU ever.
Stock cooling people report 65C idling and 80+C loaded. My GTS showed up nearly as hot with the same chip dumbed down a tad.
my reason...more x-sistors = more heat
Originally Posted by
serialk11r
What makes you think that the core will pull 150W? Just because it runs hot doesn't mean its generating that much heat. A soldering iron might only have 20W going through it but it can reach 250C or more.
