hi EnJoY
Have you manage to run these ram at 1T? I keep hang at the boot up screen when i set ram at 1T no matter how loose the timing is :(
hi EnJoY
Yea, I ran some memtest for about 100 passes at test 5. 1T is very very stable. :D
This was done with 2.3v... And despite what the MemSet shows, TREF was set to 3.9us.
http://enjoy.nickfire.com/overclocks...3361t_2.3v.jpg
the memorias of which the rbsmontemor says sao these here ddr1000 5-5- gkx
http://img244.imageshack.us/img244/672/memosaj3.jpg
Did you tested them on P35? Seems impossible to clock any kind of memory over 1100 CAS 4 :(
Help please
reaching more than 1100 cas4 is difficult on any chipset, even 680 :D
depends on how good your mem is of course :D
They forgive the bad English, more to write itself in Portuguese, would answer me?
Here they it 1200
http://www.xtremesystems.org/forums/...ght=cell+schok
I guess I'm confused as to what you need?
cool review,
tiny favor with orthos if u could plz.use only BLEND test and max priotory for 30min.the best would be if u could run a quick 30 min OCCT test (cpu+ram) on HI settings only using any timings at the rams RATED SPEED,thanks.i seen ram pass orthos for hours on large ffts then fail the blend test in 2minutes..were occt cpu+ram on hi can give real good idea in only 30min.
again thks.
"Yea, I ran some memtest for about 100 passes at test 5. 1T is very very stable."
1t,nice..any screenies?doesnt that equate to like 10+ hours?(100 passes)
Priority at 9 does not really favour cpu stability to any major extent over priority one, the extent of change is too small (if any), especially if you run both and compare failure time frames where the processor is not capable of anymore speed. Running both ways I have never seen anymore crashes in priority 1 or 9, the only thing 9 does, is make your system unusable for other tasks while it's running.
The point is that a priority 1 run should not be disregarded as substantially less stable than a priority 9. Most likely lock ups if any at priority 9 in comparison to priority 1, are due to XP services being starved of required processing time, rather than a beating of priority 1 stability.
regards
Raja
That was a very nice review, it's good to see a German RAM manufacturer perform that well! I also like your way of testing the speeds, it's very close to my own testing with MemTest and Prime95. I don't know why testing with SuperPi should be better...
I also liked your review of the G.Skill HKs, it tempted me to buy a kit... :D
However, I'm looking forward to your next review! :up:
Yah I know that...but DDR1200 4-4-4-12 is "easy" with an IN9 32x.
I have the same sticks as you, and some Ballistix Tracer PC8500. Tested 5-5-4-12 with 266 and 333 strap....both give me DDR1200 stable.
4-4-4-12 only on (on or at? sorry I aways forget that :(, I'm improving this =] ) 333 strap. I've seen a lot of DDR1200 CAS4 on P35...and a know I have good sticks coz DDR1200 @ 4-4-4-12 on (again :confused: ) 680i is easy here.
Rbs.
P5K SE
4-4-4- 1T 2,35 V
http://img413.imageshack.us/img413/1390/memo2jd4.jpg
Shot at 2007-08-12
5-4-4-8 1T 2,35 v
http://img120.imageshack.us/img120/1130/memo51tkk7.jpg
Shot at 2007-08-12
Everyone should keep in mind that this review was done nearly 6 months ago now on a less than stellar p965 board. The landscape of memory overclocking, both in terms of better ic's and better chipsets, has significantly changed since then. But thanks for all the continued comments. :)
Fine review, though pc-6400 does 1200mhz 5-5-5-15 @ 2.4v np..
Atm. my 6400 is running 1067 @ 2.25v - 5-5-5-15, quick setup, until new board and cpu arrives
Very nice review EnJoy:) I just got my sticks today and am still feeling them out!
interesting results EnJoY got the same ram from the post office today.. have to test during the week end how my dfi lp p35 likes these sticks :D
@Solarfall......Please tell me what you experience with you're sticks on this board as far as say 425 FSB X8 Multi 266/667 4-4-4-12 because I needed 2.270vdimm for 1064mhz anything less would fail within minutes! Please let me know you're findings for required Vdimm on you're end at those settings.
Thanks........Campbell:)
well before my other psu blew up i was able to clock the ram sticks to 603mhz (4-4-4-9 2T) with 2.5v, they were also very stable at 2.3v clocked to 500mhz with 4-3-3-9 latency's so they seem pretty nice :D more testing will be done when i get a replacement psu.
@Solarfall.....Which board were you running,...680i:confused: Because I am really thinking of plopping this Ram in a New System I have built to sell that has a EVGA 680i in it and a E6600 because as it stands I believe my high Voltages are attributed to the Q6600 O.C because take that out of the equation and I blend hours on end @ 1006 MHZ ...UNDER 2.1Vdimm in Bios!
