1000's all over the place, clocks and nature ... nice work.
Regards
Andy
Regards
Andy
My containers are not designed from guesswork George :D.Quote:
Originally Posted by hipro5
Sucesfull LN2 benching is 100% about load control and temperature swing. It can't be any other way when benching with 3 units.
Couldn't get a better validation on them then from the Worlds greatest "power user". Sick clocks :toast: :toast:
Very impressive hipro
big numbers coming soon :banana: :banana:
Very very nice! :toast:
When do we have to check the ORB topspots?
Good luck benching.
Really nice hipro, now we are waiting for some new WR :D
regards
Great... 1Giga... wow :toast:
Thanks guys......:)
The other VGA is cold buged at -105*C during going into windows and -115*C when idle into widnows.....It can do 1000MHz with a bit difficulty (one time does and the other not) due to higher temp and it's rams can do 1296MHz.... :D
BOTH of them can easily do 974MHz core and 1242MHz Rams - for the time been with a few fast testings...:)
Sounds like a winning pair, what vdimm are you pumping for 1296mhz George :slobber: ?Quote:
ONLY 2.34VGDDR....:)Quote:
Originally Posted by k|ngp|n
Come on Hipro go get those WR's, anyway good luck
Bob
i think vmem , lol that mutch Vgpu would blow out the core :D , whats the vgpu btw ? very nice cards george :DQuote:
Very impressive skills some WR's will be broken soon :D
1.8, see above :)Quote:
Originally Posted by blind_ripper
prolly, but you never know with this guy :D . I say vdimm he says vgpu...neither says vmem lol.Quote:
Vince.....design him a pot to cool his psu :DQuote:
Nice work George! :toast:
Yes correct .....It was a misstyped and corrected.... :)Quote:
VGPU is 1.797Volts Idle.....
:ROTF: :DQuote:
Are you crazy?.....I already spend tons of LN2 for banchies....Now with Tek-9 LN2 GPU containers, I need more of it....These dumn VGAs need too much LN2.....:DQuote:
Originally Posted by s7e9h3n
Thanks Steve....:)
hey man.. break a leg.. :D a WR this is for you man.. :toast:
Look at it this way: Cooler PSU -> More stable voltages -> Less Voltage required for running high clocks -> Cooler VGA temps -> Less LN2 to run the cards!Quote:
So overall, it would result in higher clocks, with less voltage, and less chance to kill HW! Wow, I'm brilliant :D lol....
Look......For the time been and till I construct MY PSU, I bench with FOUR PSUs.....One for the main rig, one for one VGA, one for the other VGA and one for all the fans..... :(Quote:
Hehehe..I was just kidding George.....but just out of curiousity, are the PSU's for your VGA's dedicated 12v supplies? Or are they just normal computer PSU's?Quote:
Yes all normal computer PSUs....:)Quote:
Lots of 1000's there. :slobber:
How do you deal with the multiple grounds when using all those PSU's?
While we're on the topic of your PSUs... How do you load the 5v rail on all 4?
No problem with that at all.....;)
One is main.....Second is only for fans.....The other two for the VGA's are OK....
I've tested about other 4 with no luck......They didn't start without drawing currents and one Forton, shuted down from overcurrent protection while the VGA was under full load....
I wonder how much power would a quad at 5ghz ~1.8V (or how much you need?) + 2x 1Ghz cards each at 1.8V would draw :D
