hopefulyl we will see a k10 and dual r600 setup from the AMD area of cebit. That would rock:slobber:
- paul
- paul
Which reports? Everything I've seen from AMD about dual cores indicates they expect to release them shortly after quads.Quote:
Originally Posted by brentpresley
Definitely. Does anyone here run SETI@Home? How easy is it to hack?Quote:
Its all about BOINC and not SETI@Home. I use Boinc, but i dont know how to crack it. I think it checks the system data to show the CPU. Thats why u always read Intel(r) Core 2 Duo(r) CPU balblabal @ default clock.
Meaningless. You can run SETI@Home for 30 minutes on QX6700 per day. Or you can run SETI@Home for 24 hours per day on Pentium MMX. You will get more average credits for Pentium MMX.
BONIC Average credits is calculated by amount of the work was done per day.
But if u wanna be in the toplist u need to run BOINC 24/7. And the CPUs which we are comparing are in the top 10.
Read this post:Quote:
Originally Posted by w0mbat
http://www.aceshardware.com/forums/r...6607&forumid=1
Max credits per day:
AMD Athlon(tm)/Opteron(tm) CPU-model unknown 4,208
Intel(R) Core(tm)2 Quad CPU @ 2.66GHz 12,988
omg you're pathetic... you don't even know if that's a real K10, but since you can't bash it's performance you gotta bash something... If K10 quadcores come out at the end of Q2 and K10 dual cores at the beggining of Q3 it's that still 3 months appart? And how do you know the dual cores will be cheap? And how do you know that Quadcores won't be cheap? Cheap compared with what? High-powered DC?? Are you in panic-bash-mode? You got almost more posts in this thread then everybody else combine lolQuote:
i feel that same excitement growing in my stomach as when the C2D numbers were first trickling in....
everyone got their popcorn ready?:toast:
That chart says both quads and dual cores in Q3. There might be some quads in very late Q2, but I'd expect quads early-to-mid Q3 and dual cores mid-to-late Q3. I wouldn't be surprised if ES of both were out by now.Quote:
Thanks. Just wanted to post it here myself :)Quote:
Originally Posted by kl0012
Exactly. Also I wonder how anyone concluded that the unkonw Athlon(tm)/Opteron(tm) is barcelona?Quote:
You can submit any CPU brand name/model string you want. For example: "IntelAMD", "AdvancedsMicrosDevices AMD", etc.
Just another BS from the_INQ. As always their goal is to make more traffic to their site.
Probably just a generic cheater.
Are you kidding? :)Quote:
I don't plan to give a list of options, but think over it. There are thousands of people on the net who's idea of a good time for their weekend is to write operating systems. How difficult will it be for them to encapsulate any process in any wrapper that changes "things"?
Isn't the Xeon X5350 Quad-core. That list shows it as 2 CPUs?
What does this have to do with INQ ?Quote:
Originally Posted by gOJDO
http://www.xtremesystems.org/forums/...5&postcount=27Quote:
Originally Posted by frankR
Nothing.Quote:
Originally Posted by Ubermann
boinc is easily optimized. but i do hope this is a dual core chip and it is real because think of the quad core chips:slobber: and why is this guy running seti? he should join the xs wcg team:D :p: j/k
Those are two independed systems with four cores each. See the post of Dresdenboy:Quote:
Actualy, nothing special.
Please be that real ;)
I'd like to change my sig :D
What's wrong with your sig :confused:Quote:
Originally Posted by xoqolatl
interesting ...
I was running BOINC for over 2 years on my computers. Friend of mine found easy way of increasing scores for each computed packet. You started computing packet on FAST computer for which BOINC is evaluating cpu speed/memory/hdd/... and then computing it on SLOW machine (simple copy of folder). After few days when everything is 95% computed you're moving all data back on FAST computer and let him send everything back to BOINC servers.Quote:
Of course this gives huge gains only every couple of days and is very easy to trace on daily graph. I think this is what Intel guy from Dresdenboy link is doing to achieve 12000 points per day.
I guess I'm stupid or it's time to go to bed for, but what numers should I be comparing from this boinc chart??
I mean the numbers are allover he board, slower cpus with better scores, then the same cpu has bad scores, how can anybody take anything from this as a measure of anything??
________
ALASKA DISPENSARIES
Yes, would you like some pudding?:DQuote:
Originally Posted by VulgarHandle
A definiton of pure the_INQ BS:Quote:
First solid Barcelona numbers tip up
IT LOOKS LIKE the first Barcelona number have surfaced at Seti@Home of all places. If you look at BoincStats, you will see what I mean.
