Just for comparison,this is a screenshot from hipro with a P5B dlx,during a internal contest with spi32M@3600 at thelab.gr.Quote:
Originally Posted by eva2000
Anyway,the resaults are great.I'll try it with my Striker soon:toast:
This is the best I have managed with 1TQuote:
Originally Posted by Messiah
Great job thanks 4 all ur testing.
Too bad my GeILs are total crap, they barely even run stable at rated volts/timings....
1T tops out for me at 450mhz 4-3-3-4 1T with memtest bandwidth only at 5028-5209MB/s which is short of what 600mhz 5-3-3-3 2T is at 5400+ MB/s. And i can test higher at 640mhz 5-4-3-x 2T later so definitely for my memory 2T will end up faster than max 1TQuote:
Althow I managed to reach the speed and the timmings with my Supertalent PC6400C5(2.55vdimm),I got a slower time.I am running on Windows XP lite(fresh install)with major tweaks on(maxmem,system cache,realime...).Have you done something with the other timmings in bios(tREF/tRD/Acync Latency):confused:
I have left them in auto.I also have to say that I had to set the NB voltage to 1.6v to make the system able to finish spi.
tRef and async left at auto, trd you can play with ;) :D
520mhz 4-3-3-4 2-1-2-6-20 2T at 2.3v
Now to look for a compromise between max memory clocks with high vdimm and more reasonable lower vdimm and suitable memory clocks which have very tight sub timings.
I ended up with 520mhz 4-3-3-4 2-1-2-6-20 2T at 2.3v vdimm bios set. Only ~1.39 seconds slower in 32M Super Pi than 533mhz 4-3-3-4 3-1-3-6-30 2T at 2.35v run but uses 0.05 vdimm less! Interestingly, 520mhz run was faster in 1M Super Pi due to tighter sub timings at 13.938s (520mhz) vs 13.969s (533mhz).
Super Pi 1M
http://fileshosts.com/intel/Asus/680...e_13s938ms.png
Super Pi 32M
http://fileshosts.com/intel/Asus/680...3m34s297ms.png
Everest Ultimate Bandwidth
http://fileshosts.com/intel/Asus/680..._bandwidth.png
Well 1 second faster at 3600mhz, and also did 3612mhz and 3647mhz runs to see what it takes on 680i striker to hit sub 13min 05s times for 32M
http://fileshosts.com/intel/Asus/680...3m13s859ms.png
http://fileshosts.com/intel/Asus/680...3m11s312ms.png
http://fileshosts.com/intel/Asus/680...3m04s953ms.png
eva, Great Post!!!
I'll give some of these setting a go tonight on my PLUS board w/ my Ballistix and see how they compare. Is 2.50 vdimm safe for MEM 24/7?
great review eva.. :)Quote:
i miss my chance getting the ocz vx2 at the newegg last week.. :(
very nice result.. :)Quote:
Originally Posted by The Nemesis
Originally Posted by erwinz
They are still there.
http://www.newegg.com/Product/Produc...82E16820227138
nope.. 2.5v for benching only... you'd want to keep vdimm under 2.3-2.35v if possible.. don't go crazy on voltagesQuote:
Originally Posted by H0RM0NE
If I loosen sub timings a bit more I can do 533mhz 4-3-3-4 easy at 2.3v vdimm. Tigther sub timings = more vdimm and NB volts needed.
last week thay have a good deal.. only 265$ after the MIRQuote:
Originally Posted by goatboy
here is the link of kemo6600
http://www.xtremesystems.org/forums/...d.php?t=134554
i miss this deal.. :(
This is the best I could do on 1T topped up phil by a sliver :D:D:D
This is also at 3.6ghz
I can't manage to do anything on 2T with this 1002 bios.
Yes!. 680i loves tight memory timings and is exellent memory overclocking board.
I have 2gb dualchannel D9D running DDR950@4-3-3-1T and its only at 2,25V!
Im not using dualcore CPU yet. Im running Celeron D356@4,8Ghz. 1,47V
PC does Spi under 29sec. Friend is running badaxe2 and same celeron with same D9D. He can get timings only ddr950 4-4-4-2T and he has Spi time only ~31sec.
http://photo.ringo.com/190/190958620O741673603.jpg
very nice tight timings.. :)
eva or anyone else with the striker board...
will the p5n32-e sli plus be able to do this or does the nb chip play a factor since the p5n32-e plus and striker/p5n32-e non-plus have different NB chips?
Originally Posted by shimmishim
From what I've been reading, there is virtually no performance difference between the boards.
hey eva what did you set your trd to?
Tip of the cap to Eva2000 for yet another great thread. I finally got around to playing with my eVGA mobo (two months late) and the fun factor on memory is very high! I'm still testing out CAS5 and have started to tighten the secondary timings. However (little bit off topic) I have a question regarding tRTC and if there is a big jump in voltage required to drop it down to 3. My board violently objected at the same vdimm and a quick .05 jump didn't change a thing. I'll try to push a bit more on speed and go after the secondary timings again and include Memset in the screenshot so you can see them when I'm done. In the meantime here's where I am. Suggestions very welcome. :D I had the wrong tab up on the CPU-Z shot that had the memory ID. These stick are the ones from the Deals section titled BUFFALO Firestix 2GB (2 x 1GB) DDR2 800 (PC2 6400) $174.98
http://img170.imageshack.us/img170/6...asp3trame3.png
Quick update. Getting anxious to try out CAS4 now. Had a hard time getting under 14minutes.
http://img177.imageshack.us/img177/2...tightersv7.png
very nice memory for a price like that.. :) thanks for sharing..Quote:
Originally Posted by gundamit
thanks guys
gundamit nice clocks there - and yes tRCD/tRTC of 3 needs more vdimm which further supports the fact that tRCD of 3 is faster than 4 value and is in fact real .. maybe ?
ineedaname, try between 1 and 7... 7 i think is default value when AUTO is set for tRD
Here ya go...
