Dude this so flipping cool. May i ask how old you are...seam a very young and talented guy...love your paint job on the plexi!
Thanks guys!
bluep3ace: Thanks, I will stick to the spikes, as it was one of the things that I really wanted to have on this case.
Pete: Thanks! :). I'm 16 at the moment, 17 in just a couple of days. :)
Very detailed work. Good job and a lot of pictures :toast:
very nice job.... i also like the tinted plexi.. i have seen some tinted plexi that looks solid black when the computer is off.. :D :D :D :D :banana: :banana: :banana: :eek: ;) ;) ;)
Resently came back from USA, so got some watercooling-stuff with me :)
The order from PT
http://img340.imageshack.us/img340/6076/ordergs1.jpg
The CCFL's seem to be pretty strong
http://img337.imageshack.us/img337/6105/222rt3.jpg
They are lightning up my room pretty good, should light up the case as good as well, don't you think?
http://img78.imageshack.us/img78/2469/224fm2.jpg
4 logisys White ccfl
http://img77.imageshack.us/img77/4685/225sm3.jpg
Swiftech 18w MCP355 with Petras top, DD highflow barbs and sleeved cables, Swiftech MicroRes with DD higflow barbs and a modified barb so it will with in the PG7-thread at the top of the res. And ofcourse the DD- Fillport
http://img254.imageshack.us/img254/3286/226yd6.jpg
http://img49.imageshack.us/img49/4259/227jd8.jpg
http://img460.imageshack.us/img460/4249/228gz2.jpg
Fillport..
http://img117.imageshack.us/img117/3043/229my4.jpg
Swiftech MCRes, nice and tiny little fellah
http://img117.imageshack.us/img117/9021/230bi7.jpg
Watcha think?
//NysoO
nice work!
Keep coming! I want more photos :)
BTW, very good work you doing there
Very nice work!! Hope to get some advice from u in the future :)
where is the final system,i am very curios.show final images please...
mit78: Hehe, still under progress, so no "final" - pictures :)
cirthix: thanks! :)
rbsmontemor: Thanks, you can be shure that there will be more photos. I have clear-coated the case, so that the polish wont oxide. Pics on that later, although you can't see much difference.
PlatoonSgtElias: Thank you, I'm sure I can give advices. What do you want to know? :eh:
Man, I aways want to do something like that.....but I have no time and no experience. In your first post you give so much detail and photos, I spend almost a hour looking at :slobber:
I'm waiting for more photos (when necessary, like u said:)).
Sorry for my fu*¨%ng terrible poor english :slapass:
Again, good work
Bye :wave:
its beatiful
i wait the pictures.
Great work man , damn you had the same idea as me to make the microres fillable via the DD fill port, I cannot find any barb that fits the thread of the fill hole.. did you custom made that part or is it availble through local dealers ?
Thx for any info...
Leeghoofd: If you compare the fillcap to a, for example DD highflow barb, you will notice that the barb's thread has a wider diamater in a total.
The thing I did was to place the barb in a wice, thereafter I took a file and filed the thread all around. Then to make the threads better, I found a small special file that i filed IN the threads with.
After some work I tried the barb in the Res, and if I found some place where the barb was hard to screw inte to res, I filed it down or changed it so the barb would fit in the res better.
http://img209.imageshack.us/img209/6800/232jg2.jpg
http://img329.imageshack.us/img329/5045/233pl8.jpg
http://img136.imageshack.us/img136/1186/234ff8.jpg
Impressive work, keep us posted.:woot:
Very nice. I like the front door.
Can you send one modded barb over plz , I have no patience to do this stuff, I want to make a top on my cube and be able to fill the bugger from there and not detach all stuff... (my bad design lol)
I have sprayed a clear-coat on the chassi and tried some new mounting-positions of the watercooling.
Sleeved the start-button
http://img516.imageshack.us/img516/9994/235pq1.jpg
Can you see the clearcoat mirror?
http://img169.imageshack.us/img169/1249/236cs9.jpg
It almost melts into the surroundings :P
http://img406.imageshack.us/img406/723/239xk4.jpg
The new pump made it possible for me to mount everything internally, which also will take away the problem with the upside - down mounted rad.
http://img405.imageshack.us/img405/2802/240rk6.jpg
http://img339.imageshack.us/img339/7683/241kg5.jpg
Have been trying some loops, any suggestions?
http://img111.imageshack.us/img111/5138/243ab9.jpg
http://img339.imageshack.us/img339/4977/242ci5.jpg
nice work...what you puttin in it???mobo &pro.....????
That's simply amazing. Great work man.
I like it, is nice!
props for some hard work on a mod that is coming out great so far, subscribed ;)
Hmmmm...this is VERY impressive alright, nice workshop you got there ;) I'm seeing too many of these mods, I want to make a case myself. :D
As for your watercooling loop, parallel rads will be difficult because of the size of the case. I'd flip the pump sideways, so the inlet barb is pointing straight at the res, and have the pump either pump right into the 120.2 rad, or right into the CPU or GPU.
very impressive work
That must have taken you really long time.
It looks really good i must say.
Keep up the goodt work
